Laptop power issue, sometimes wont charge.
1
i don't exactly know where the best place to put this tread is, or if this is even the right forum. But i'll make a post here anyways.
So two days ago my laptop was not able to turn on at all and so i checked the ac adapter and it was beeping so i got brought a replacement from Canada Computers.
So everything after here is with my new ac adapter:
Now it powers on but if the power is connected after the computer starts up then the ac adapter is beeping and the computer no longer receives power but after a random interval of time the beeping stops and computer is charging again.
However if i put in the power line before the computer starts the power line is beeping at first but once i boot the computer the beeping stops and windows shows the power as connected.
Also when i change the Battery Mode in the Lenovo energy management panel the power disconnects and the ac adapter starts beeping again and after another interval of time the power is recognized by windows again and the beeping stops.
As well if i plug out the power supply from the laptop and plug it back in it takes a random interval of time for the power to come and there is also beeping.
So is there anything that i can do to fix this problem.
Thanks,
Harry
    Windows 8.1 Pro x64
alphanumeric
slightly off center
Gold Member
Remove the battery and then power up and see if it boots up normally with no beeps. If the battery has failed and shorted out it may be drawing too much current and overloading the charger/power pack.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
