Are there any laptops that have at least 1080p, a big hard drive, and at least 4 USB TYPE a ports (this seems to be the hard part to find). Every laptop I have seen has at most two USB TYPE a ports.
- Windows 8
You're right, it's very unlikely you'll find a laptop with that many USB ports, especially USB 3.1 or 3.2 Type-A. It's usually limited to 3 ports, and 1 of those is usually the older USB 2.0Are there any laptops that have at least 1080p, a big hard drive, and at least 4 USB TYPE a ports (this seems to be the hard part to find). Every laptop I have seen has at most two USB TYPE a ports.
terrypd - If you'd like to discuss desktop vs laptop, I'd recommend that you start a new discussion thread for that.
I have exactly that layout on my laptop, so I got more Type-A ports by adding a small hub. The clever design clamps onto any convenient surface you may have. It has a rubber strip so it's safe to clip it to your monitor, for example. I clipped it to the end edge of my desk which places it within easy reach, and attached cables dangle out of sight. We got the silver finish version but there's also a black finish version. Check it out:
ORICO USB 3.0 HUB, Monitor-Edge and Desk-Edge USB 3.0 4-Port Clip-Type Hub - Newegg.com
Buy ORICO Aluminum Powered USB Hub With 4 USB 3.0 Ports, Compact Space-Saving Mountable with Extra Power Supply Port and 4.92ft USB Data Cable, Ultra-Portable USB Expander for MacBook Air/Laptop/PC with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.com
