Key change from 8.1 Embedded Industry Pro to 8.1 Pro
Hey guys,
I'm running a Dreamspark version of Windows 8.1 Embedded Industry Pro but it seems that this version is not entitled to a free upgrade to 10. I'd like to move to a retail 8.1 Pro and I was just wondering if I'd just be able to use the 'change key' feature without having to reinstall the operating system.
Cheers
    windows 8.1 embedded industry pro
popeye
United States
3,090
I did not know Dreamspark provided operating systems, I thought it was apps only. When you choose to upgrade within Windows does it give you the 8.1 Pro option?
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
Thanks for the reply. Dreamspark does indeed offer some OS options.
Unlike retail versions, there's actually no upgrade option in this version of windows, only a 'change product key.' This is on the system information screen.
popeye
United States
3,090
I would simply try it and see if it takes. It should reject if not compatible. I don't think it will work as pretty sure it is not up-gradable from what is a student/teacher licence. Will most likely have to fresh install 8.1 Pro.
No word on a 10 Dreamspark being released?
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
alphanumeric
slightly off center
Gold Member
Add Features on the System screen is how you would upgrade from 8.1 to 8.1 Pro or add Media Center to 8.1 Pro. I don't think change key will do anything for you. It will be looking for another 8.1 Embedded Industry Pro key and reject anything else. If you have the 8.1 Pro install media, boot from it and see if you get an upgrade option. Running the setup.exe on the install media from your current Windows install is another way to do it. I have my doubts that it will let you upgrade but there is nothing lost in trying. Just click cancel if you don't get an upgrade option.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Nothing from Microsoft yet. I've been holding off on getting a retail 8.1 pro for this reason, but I think I'll just go ahead and get one to avoid future hassles.
Thanks for that. I'll prep a boot usb later on this week and give it a shot.
