annihilator2k7
I'll start off by saying that any attempt I've made at changing settings in order for the BSoD to give me a minidump has been a failure. Any time the BSoD comes up, the error report gets stuck at 0% indefinitely.
This error has been popping up daily for a little over a week now, right after I upgraded my GPU, CPU, and CPU fan. The error does not appear to have any triggers as it happens either when the PC is under load or when it is idle with no programs open. I've monitored temps to make sure the CPU fan was correctly installed and the CPU never goes beyond 40C.
I've run Chkdsk which resulted in no errors.
I've run windows memory diagnostics which resulted no errors.
I've run sfc /scannow which found an errors that it could not automatically fix. I do not know how to find the error in the log file.
- Windows 8.1
