Solved Keep losing wireless connection, have to disable and enabl
Kaninchen
Every so often (it could be 5 minutes or an hour) I lose my connection. Then I have to disable and enable my wi-fi adapter (a Linksys USB adapter) to get it to work again. Usually that works until the next disconnection. However, sometimes even when I disable and enable it won't work for a few minutes of waiting and disabling and enabling again. I can connect to either a 5ghz connection or a more standard connection (I can't remember the ghz.. I think it's 2.2-2.4 or something), but I have the same problem either way. I've been having this problem for the past couple weeks or so. Before that I had the exact same connection set up and didn't have the problem.
Here's what it looks like when I'm connected:
Here's what it looks like when I get disconnected:
Finally, here's what it looks like when I disable the wi-fi adapter:
Any help would be much appreciated.
    Windows 8.1, 64bit
    IntelCore i7-2600K CPU @ 3.4 GHz 3.7GHz
    16 GB RAM
    NVIDIA GeForce 8800 GT
Kaninchen
[Edit: I added some information here, but I had it slightly wrong.]
    Windows 8.1, 64bit
    16 GB RAM
Kaninchen
Things I've tried:
-Resetting computer
-Resetting modem
-Resetting router
-New wireless adapter
No changes to the problem.
    Windows 8.1, 64bit
    16 GB RAM
popeye
First, make sure you have latest driver installed here (click on the hardware version): Linksys Official Support - WUSB6300 Downloads
Then be sure all power saving features are turned off for your USB ports and WiFi adapter in Device Manager and Advanced Power settings.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
popeye
Glad it worked. :)
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
