Solved Keep getting USB connecting sound
madmecca
Hello just wondering if anyone knows why I keep getting the USB connect sound from my pc. It's not all the time it happens occasionally but bugs the hell out of me thanks in advance
Hello madmecca
Do you have any USB devices plugged in when the sound occurs? If so, try unplugging them to see if that stops the sounds. This will also give some clue as to the device that may be causing the issue because it appears that something is intermittently losing the connection and then re-establishing same. Also, could you please provide/update your system specs as well?
my2cents
