KB2976978... again, and again !
Mooly
I have KB2976978 installed (install dated 18th June 2015). Today this update appeared again as an optional along with KB3065988. Both were installed successfully and PC restarted as requested. I then left things for 20 minutes and did another restart to ensure all files were placed correctly. Left again for 15 minutes and then I run disk clean + system file clean. All OK. I then rebooted for a final time and was presented with a 'Important Updates Are Available' message on the log in screen. Checking Windows Update shows KB2976978 once again available, even though it was successfully installed only an hour or so ago.
Sounds to me like some aberration on the part of Windows Update. I'll wait and see if it disappears from the list tomorrow.
    W10 x64 pro and W8.1 x86
    Dell Vostro 3750/Acer 9301
    Intel i5/AMD Turion 64
    4Gb/2Gb
    Intel i5 internal/NVidia GEFORCE GO 6100
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
I had 2 to day also.
The KB# is the same but size was different.
KB numbers just say for what it is, but, they are two different updates all together.
Like the daily AV updates for Defender, one KB is for virus definition another is for spyware, and a third is for Defender version itself. Hope this helps:)
    Cliff's Black & Blue Wonder
    Intel Core i9-9900K
    ASUS ROG Maximus X Hero
    hanteks Enthoo Pro TG
    Trust GTX THURA
    Trust GTX 148
    25+/5+ (+usually faster)
    Edge; Chrome; IE11
    Router: FRITZ!Box 7590 AX V2
Hi again, Mooly. I have 2 desktops and a laptop dointg what you describe....over and over. I finally simply "hid" the update and it quit appearing again.
    HP Pavillion p6230f
    HP AMD Phenom II X4 810
    FOXCONN ALOE
    8 GBytes
    ATI/AMD Radeon HD 42
    ATI/AMD SB600 - High
    Dell SE198WFP
    1440 x 900
    Seagate ST3750528AS
    IE 11
Thanks Cliff.
So just to be clear, you had two KB2976978 updates offered today ? one after the other.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
Thanks John, posted together I think. I'm going to wait and see if it drops off the update list.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Hmmm, that's clear enough. And the size was different you say, suggesting it really is a different version.
I'll think about it.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
Looking under installed updates and I see only one entry which is todays. The previous date of 18th June, when this update was first installed and which shows in the normal update history, has no corresponding entry in June 'installed updates'.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
OK, I've clicked it. My update screen now looks the same as Cliffs'.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
And its now asking again. This has to be a rogue update. Offered and installed twice in succession, and now its appeared for a third time.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
Very strange update indeed and so SMALL in size (?) , won't stop showing up, BUG?
Cheers
    Windows 8 Pro x64
    Apple Mac Pro 5.1 (2012)
    DODECA @ 2.66 GHz
    MP 5.1
    24 GB @ 1333 MHz
    EVGA GTX-670-4GB-FTW-PC & ATI XT 2600 HD Mac
    Samsung 840 EVO's 500GB @ Apricorn Velocity DUO x2 PCIe
    The most beautiful IMHO
    Wired
    Mighty Mouse
    ESET Internet Security Pro
I also have this problem. There is further concern because this problem causes windows update not to check for further updates - I know there are more because I reinstall regularly
    Windows 8.1 Professional N
    Acer E71
    I3
    6GB
    Shared
    Multiple
    None
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
Sorry for not replying sooner, Mooly - I had a knee replacement last week, am on pain pills and not too sane at this point. However, I had problems with KB2976978 this week installing over and over and over again on my desktop. I finally just "hid" it so Windows Update couldn't find it each time it searched even tho I had not installed it. Screenshot attached of the hidden update - 25mb -hope this helps you.
    HP Pavillion p6230f
    FOXCONN ALOE
    8 GBytes
    Dell SE198WFP
    1440 x 900
    Seagate ST3750528AS
    IE 11
I just checked my Win8.1 Pro and KB2976978 installed on 6/9/2015, haven't had it offered since.
    WinXP, WinVista, Win7, Win8.1, Win10, Linux Mint 20
    2 Customs and 12 OEM/Brands
    AMD and Intel
Yup I received another on and installed, again it was a different size:
This update performs diagnostics on the Windows systems that participate in the Windows Customer Experience Improvement Program in order to determine whether compatibility issues may be encountered when the latest Windows operating system is installed. This update will help Microsoft and its partners ensure compatibility for customers who are seeking to install the latest Windows operating system.
It's getting me ready for Windows 10.:D
    Intel Core i9-9900K
    Trust GTX THURA
    Trust GTX 148
    Edge; Chrome; IE11
Hi John, hope the knee settles down... it will be worth it in the end I'm sure.
For curiosity I rolled back to 7th June image and let Windows Update do its thing again. As before, the same two updates are offered. I installed them, ran a disk clean, reboots and so on, and...... no more offerings ! I forced an update check and again, nothing there.
Methinks MS are making all this up as they go along.
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
My "hidden " update has now disappeared from the hidden list and no further problems showing - think you are correct Mooly , they are making this up as they go. It's probably sorting itself out but not fast enough for those of us who like a little "order" in our life - lol.
    HP Pavillion p6230f
    FOXCONN ALOE
    8 GBytes
    Dell SE198WFP
    1440 x 900
    Seagate ST3750528AS
    IE 11
I had installed KB2976978 yesterday and WU offered it again. I ignored the 2nd offering and when WU ran this afternoon it disappeared so all is good.
Jim :cool:
    ASUS - Home Built
    AMD Phenom II X6 1100T
    ASUS M5A99X EVO
    MSI R6850 Cyclone IGD5 PE
    On Chip
    Corsair 400R
    AVS Gear Blue LED Backlight
    15MB
    NIS, Malwarebytes Premium 2
    Epson V300 Scanner
    4Gb/2Gb
    Realtek
    250Gb SSD and 120Gb
    HP Z4000
    76 down, 20 up
    MS Edge
    Defender
