KB2919442 installed then not installed
Bazzer
Hi,
I'm using Windows 8.1 Pro 64 Bit
If I go to Control Panel/Windows Update/View Update History KB2919442 is shown as installed successfully on the 12 March 2014 "BUT" if I go to Control Panel/Windows Update/Installed Updates there is no KB2919442 listed.
If I download KB2919442 directly from Microsoft and try to install it manually it says "This update is not applicable to your computer"
I'm obviously having no success trying to install KB2919355 as it never shows as available in Windows Update and if I download it manually from Microsoft and try installing manually I get the same error message "This update is not applicable to your computer"
    Windows 8 Pro 64-bit
archer
Hi, Welcome to Eight forums.
check out this tutorial. Might be of some help.
    Windows 7 x64/ Windows 8.1 x64
    Self Made
    Intel i5 2500K @ 3.3GHz
    Asus Z68 V Pro
    16GB DDR 3
    HIS 6870 ICEq edition
    Samsung 22" Display
    WD 1 TB
    Seagate 2 TB
    WD 320 GB
    coolermaster 750 W
    Coolermaster HAF 912
    TVS Gold
    Samsumg
    4 Mbps
    AVG 2013 IS
Bazzer
Hi Archer,
Thanks for the reply but I don't think there's a solution to my problem in that tutorial.
At no time do I get an error code, I just get the message "This update is not applicable to your computer" and there's no joy running the DISM tool as I've never got as far as installing KB2919355 because KB2919442 doesn't seem to be installed fully.
I think I need to get KB2919442 installed properly first
archer
    Self Made
    Asus Z68 V Pro
    16GB DDR 3
    Samsung 22" Display
    WD 1 TB
    Seagate 2 TB
    WD 320 GB
    coolermaster 750 W
    TVS Gold
    Samsumg
    4 Mbps
    AVG 2013 IS
Bazzer
Hi again Archer,
I changed the Format from English (United Kingdom) to English (United States) but unfortunately I still get the same error "This update is not applicable to your computer".
I tried both KB2919442 and KB2919355 but they both gave the error
