Issue with Network Infrastructure and Network Map
Grimroid
5
All
I have attached 2 pictures to show my issue.
First of all I have a Netgear R6300 wireless router. On the Network window is shows as a gateway. I am pretty sure it was displaying as a router on Windows 7.
Second when I try to get display the network map I get the error message that is attached.
Could anyone figure out how to display the Network Map?
Thanks
Grim
    Toshiba
    i7
    8 gig
Mystere
1,925
I don't think it's anything to worry about. Most likely, you don't have UPnP enabled on the router, so Windows thinks it's a gateway. The only difference between a router and a gateway is that a gateway works between two dissimilar network types. For example, a Cable Modem is a gateway.
The error message is just saying it doesn't know how to manage it, which is probably as I said with no UPnP enabled.
    Intel i7 3770K
    Gigabyte Z77X-UD4 TH
    16GB DDR3 1600
    nVidia GTX 650
    Onboard Audio
    2560x1440 + 2x 2048x1152
    Antec SOLO II
    Logitech MX
Grimroid
5
I have a correction. It has always been a gateway.
The issues is I still can't get the network map on Windows 8 but have no problem on Windows 7.
Grim
    Toshiba
    i7
    8 gig
Grim
The Network Map no longer works in Windows 8.
It's fairly typical to see incorrect info placed in the Network infrastructure. It may be reading the MAC address incorrectly.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
