Issue: Main display doesn't work when HDMI is plugged
fieskmask
4
Hi guys, just found out this place, seems to be a good forum so I try it here.
Last night I got hold of a 27" BenQ GL2750HM, so far so good.
I have my main display from the DVI port to HDMI port on the screen and my secondary screen is my 60" TV which is connected through HDMI port on the graphic card into the HDMI port in my reciever.
The main scheme for my setup is like:
- Radeon 7970 DVI > HDMI Main monitor (BenQ GL2750)
- Radeon 7970 HDMI > HDMI Reciever (ONKYO TX-NR609)
- ONKYO TX-NR609 > 60" TV
So to the problem now.
When the HDMI cable is connected to the graphic card, I need to have my TV ON in order for my main monitor, the BenQ, to work and if I turn off the TV the BenQ is getting black, like a standby mode, however, there is "no signal" to the monitor.
This was never a problem with my other screen, I could have the HDMI cable connected to the graphic card, the TV off and the reciever OFF without the main monitor went black.
I hope I expressed myself good enough for you too understand, if not, please reply :rolleyes:
Thanks in advance.
Simba
Hardcore Gamer
Manchester
47
All I can suggest is to make sure your card is seated properly and to reinstall your gfx drivers.
    Windows 8.1 64 Bit
    Me
    AMD Bulldozer FX-8 8350 Black Edition @ 4.5GHz
    Asus Crosshair V Formula 990FX
    Corsair Vengeance 16GB DDR3 PC3-12800C9 1600MHz
    Gigabyte ATi R9 280X Windforce OC
    Sound Blaster X-Fi 2 MB
    Samsung Syncmaster SA350 22" LED HDMI
    Seagate Barracuda SATA II 500GB 16MB Cache 7200.12
    Corsair Professional Series Gold AX1200 (1200Watts)
    Antec 1200 Ultimate Gaming Case
    Antec Kúhler H2O 620 CPU Watercooler
    Logitech G510
    Corsair Vengeance M65
    Upto 40Mb/s Fibre Optic Broadband
CountMike
Belgrade , Serbia
4,664
Make sure you have right DVI to HDMI adapter, if it's a DVI-D output from video card it does not properly "translate" to HDMI, That adapter should have all the pins on it, some don't.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
fieskmask
4
Well, everything worked fine with my other monitor, so there is nothing wrong with the cables.
