Is it possible to switch out SDD's?
pwilson471
Dallas, TX
17
I was wanting to dual boot Win7 and Win8 but I just want to switch out the SDD's to this. Is this possible? Or will the secure boot thing mess up the Win8 installation?
    Windows 8.1 Professional
    Homemade
    Core i7-4930K
    Asus P9x79 E-WS
    Gskill 32gb 2133Mhz
    2 x 780ti's
    Asus 27 144 Mhz panal
    1920 X 1080
    1tb SSD
    Antec 1200 watts
    Internet Explorer 11.0.2
Clintlgm
Active Member
Lacombe, Louisiana
894
Well it seems that if your removing your SSD that has the win 8 install, it would never see the Win 7 installation If it doesn't turn off secure boot in your BIOS
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
brkkab123
Melbourne,FL.
187
It kind of sounds like he wan't to use a seperate ssd for each o.s. I'm not sure on the fundamentals of SecureBoot in your U.E.F.I. as far as Windows 7. I don't think it work's in 7 though, as it was a new feature added to Windows 8. Thus, I'm unsure how you'd go about it for both, but I would leave it enabled for 8/8.1/8.1 Rollup 1. It keep's rootkits off your pc at startup.
    Windows 8.1 Pro w/Media Center x64
    self built
    AMD FX 8350
    Asus Sabertooth 990fx r2.0
    G-Skill Ripjaws-X DDR3 2400 16 gbs.
    MSI N760 TF 2GD5OC
    on-bord Realtek ALC 889/ALC 892
    ViewSonic VX2250wm-LED
    Samsung 840 Pro 256 gb. ssd. & Seagate Barracuda 7200.14 3.o tb.
    Corsair HX-850 watt
    Corsair Carbide 500r White
    Corsair Hydro Series H-100, 3 120mm. & 1 200mm. case fan's
    Logitech wired
    Logitech wired
    30 m.b.p.s.
    IE 11 & Firefox 26
    BitDefender Internet Security 2014
    Iomega Pro Series U.S.B. 2.0/eS.A.T.A. 2.0tb. h.d., Seagate Backup Plus U.S.B. 3.0 3.0tb. h.d., Hauppage WinTV HVR-1850 t.v. tuner, Logitech x530 5.1 speaker's, Logitech c615 webcam, Logitech h150 headset, M.S. Xbox 360 wired gamepad & Xbox 360 as W.M.C. extender
pwilson471
Dallas, TX
17
Thanks for the quick replies. And yes I would like to use seperate SDD's for each O/S. I have an Asus p9x79E-WS. It has a
UEF-Interface. I would set up Seven with a EFI Bios Mode but no secure boot. I also know that enabling Windows Eight secure boot is well .....secure as brkkab123 stated above. Would that cause problems? Maybe I should just follow the tutorial on Dual booting Win7 and Win8. hmmmm..
    Homemade
    Core i7-4930K
    Asus P9x79 E-WS
    Gskill 32gb 2133Mhz
    2 x 780ti's
    1920 X 1080
    1tb SSD
    Antec 1200 watts
Clintlgm
Active Member
Lacombe, Louisiana
894
I think I would follow the tutorial. I did a dual boot on my P7P55D-E Pro, of course it did not support Secure boot, I had Win 7 SP1 Pro on and added a SSD installing Win 8 there. Worked great as long as I kept win 8 in control, once I change the boot to to windows 7 I had to go though the Win 7 dual boot process which is several click longer routine. Leave Win 8 the priority boot and your only 1 click away for booting your windows 7 system. I wouldn't worry about secure boot until your fully on win 8. Its really a pain in the butt anyway if your a power user.
    Windows 8.1 Pro MC
    Z97 Pro
    VIA 6.0.10.1600
    30 down 3 up
    Explorer 11
