IRQL_NOT_LESS_OR_EQUAL ntkrnlmp.exe have me stumped
Tkam
2
I have the last 2 month been trying to figure out why my PC keeps crashing. This started after doing a clean install of Windows 10 Home x64. The crash happens when playing games, has never happened while just browsing.
Current setup:
  • Inte Core i5 4670K @ 3.40GHz
  • Crucial DDR3 8gig x2 / Corsair DDR3 4gig
  • ASUSTeK Z97-P motherboard
  • MSI GeForce GTX 970
  • Corsair Force GS SSD (windows) / Samsung SSD 850 EVO 1TB / Western Digital 2gig
Things i have tried (it obviusly didnt solve the problem though).
  • I have tried a clean windows 7 install
  • Reinstalled windows 10 several times during the testing.
  • Run driver verifier several times
  • Replaced the Motherboard along with new memory sticks.
  • Checked all USB items, to make sure they are not the cause (keyboard, mouse, etc)
  • Checked all my HDDs. I unplugged them all, and just put in a brand new one, and installed a clean install of Windows 10
  • Replaced the PSU - thats the gap between the 6th to the 12th when looking at the dump files. Computer ran fine for a few days.
  • Tested with another graphics card, an AMD card.
  • Done stress test on CPU, GPU and memory
  • Monitoring heat, and while playing games my CPU is around 50 - 60 degrees, and heat on other parts looks fine.
  • Run Malwarebytes Anti-Malware
I have now basically a whole new computer, exept for the graphics card (which is not the cause of the bluescreens) and my CPU, and the case itself. I have another CPU i will be testing tomorrow, and im going to get a new case (was going to do that either way, so.)
But i cannot find anything useful in the dump files, nor in the windows system log.
At this moment, i have run out of ideas and stuff to test. I am completly stumped, and apart from trying another CPU and case, there is nothing else i can think of doing.
    WIndows 10 x64
Tkam
2
After searching through all whole bunch of BSOD posts, i found a link to the Intel Processor Diagnostic Tool and ran it. The CPU Frequency failed. I'm not entierly sure what this means tho.
--- IPDT64 - Revision: 3.0.0.23.W.MP
--- IPDT64 - Start Time: 2016-02-14 16:34:43
Processor 1
Intel(R) spbc Module Test
Module Version: 1.0.7.64b.W
Start Time: Sun Feb 14 16:34:43 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
End Time: Sun Feb 14 16:34:43 2016
Total Time: seconds: 0
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Temperature Test
Test Result - PASS
Expected: Greater than 1 degrees below max
Received: 64 degrees below max
CPU Brand String Test
Test Result - PASS
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Module - CPUFreq.exe did not create a results file.
--- IPDT64 - Temperature Monitor Results
Temperature Monitor will begin when CPULoad Test starts
Temperature Monitor Stopped
System Information
Processor Name: Intel(R) Core(TM) i5-4670K CPU @ 3.40GHz
Processor Information: Intel64 Family 6 Model 60 Stepping 3
Number of Physical Cores: 4
Number of Logical Cores: 4
Installed System Memory: 20 GB
Operating System: Microsoft Windows 10 Home 64 bitar
Graphics Information: NVIDIA GeForce GTX 970
System Product: Z97-P
System BIOS: 2803
System Serial Number: System Serial Number
--- IPDT64 - End Time: 2016-02-14 16:34:44
--- IPDT64 - Result: Fail
FAIL
    WIndows 10 x64
cluberti
Cat herder
Redmond
651
    Windows 8.1 x64
    Custom
    Intel Core i7 4790K @ 4.5GHz
    Asus Maximus Hero VII
    32GB DDR3
    Nvidia GeForce GTX970
    Realtek HD Audio
    1x Samsung 250GB SSD
    4x WD RE 2TB (RAIDZ)
    Corsair AX760i
    Fractal Design Define R4
    Noctua NH-D15
