Solved IRQL_not _less_or_equal only when streaming (flash ?)
9det
10
ONLY happens when streaming (on websites like gamespot.com, where I suspect the streaming player is flash based)
Youtube works just fine (HTML 5)
Please help !
T.
9det
10
Happened again, oddly enough I could stream legacy videos in flash on youtube (no issues) but the moment i go on gamespot ==> BSOD
usasma
Mr. Cranky Pants
5,139
Your BIOS dates from 2010. Please check at the manufacturer's website to see if there are any BIOS updates available for your system. Also check the readme file to see if they apply to the problems that you are having. Please be advised that flashing the BIOS is a very unforgiving process - and one mistake can physically damage your motherboard.
We've seen a number of BSOD issues with SSD's. Here's the information that I've compiled so far:
There's not a whole bunch available to test SSD's. The "easiest" test is to remove the SSD, install a platter-based hard drive, install Windows and test for stability that way.
Here's some suggestions:
- Update the SSD's firmware to the latest available version (VERY IMPORTANT!!!)
- Update the motherboard controllers drivers to the latest available version from the controller manufacturer (NOT the mobo manufacturer unless you can't find any on the controller manufacturer's website)
- Slow the memory (RAM) down to the next slower speed (I've only seen one person who claimed that this worked for them).
- Use any manufacturer's utilities that you may have. If you don't have any, then try this free one (I haven't used it myself): Crystal Dew World
- Update chipset and storage controller drivers to the latest available from the manufacturer of the device (not the manufacturer of the motherboard). Be sure to update ALL controllers on the motherboard!
....NOTE: Recently (Nov 2011) we had BSOD issues with the Marvell 91xx controller and an SSD. You may have to switch controllers also.
- Replace the SSD with a platter based hard drive and see if that stops the BSOD's. If it does, then it's likely that there's a problem with the SSD OR an incompatibility with your system.
It's my opinion that SSD's aren't reliable enough (with current hardware) to be used on a system that needs to work reliably. Until I see reliability I will not recommend, nor will I use, SSD's for critical applications.
06 Dec 2011 - This post tends to confirm issues with certain SSD chipsets and certain controllers - [SOLVED] cant find the cause of BSOD F4 - Tech Support Forum
29 May 2012 - The frequency of BSOD's with SSD's seems to have been decreasing over the last several months. It may be approaching time to re-evaluate my stand on their suitability for use in production systems.
10 Nov 2012 - I'm seeing an upswing in SSD errors - but most appear due to older storage controller drivers. I strongly suggest NOT using storage controller drivers that don't date from 2012 (if none are available, don't connect an SSD to that controller)
05 Jan 2013 - very interesting post about difficulties with the Marvell controllers even when not connected to the SSD drives: https://www.eightforums.com/bsod-cr...-pc-reboots-when-waking-sleep.html#post169956
This device is disabled:
Iomega Virtual Ethernet Adapter ROOT\ROOT&VNICDRV\0000 This device is disabled.
Is this deliberate? If so, why? Please either uninstall the device from your system or:
- enable the device
- update it's drivers
- disable it again (if so desired)
All memory dumps blame your network drivers. Please:
- download a fresh copy of the latest Win8 compatible drivers for your wired network card
- uninstall the current wired network drivers
- install the freshly downloaded wired network drivers
- monitor for further BSOD's
Do the same thing for your wireless network drivers as they showed up in at least one of the memory dumps.
If you have the Comodo firewall installed, please let us know (and uninstall it). Make sure that you enable the Windows Firewall after uninstalling.
ATK64AMD.sys Tue May 12 21:04:54 2009 (4A0A1CB6)
ATK Hotkey ATK0101 ACPI UTILITY Driver
http://www.carrona.org/drivers/driver.php?id=ATK64AMD.sys
ASMMAP64.sys Thu Jul 2 05:13:26 2009 (4A4C7A36)
LENOVO ATK Hotkey ATK0101 ACPI UTILITY
http://www.carrona.org/drivers/driver.php?id=ASMMAP64.sys
kbfiltr.sys Mon Jul 20 05:21:42 2009 (4A643726)
Dritek Keyboard Filter Driver
http://www.carrona.org/drivers/driver.php?id=kbfiltr.sys
MBfilt64.sys Thu Jul 30 23:40:32 2009 (4A7267B0)
Realtek HiDefinition Audio driver (file labelled as Creative Audio Driver)
http://www.carrona.org/drivers/driver.php?id=MBfilt64.sys
HECIx64.sys Thu Sep 17 15:54:16 2009 (4AB293E8)
Intel Management Engine Interface
FLxHCIc.sys Fri Sep 24 07:15:24 2010 (4C9C884C)
Fresco Logic xHCI (USB3) Device Driver
http://www.carrona.org/drivers/driver.php?id=FLxHCIc.sys
FLxHCIh.sys Fri Sep 24 07:15:32 2010 (4C9C8854)
Fresco Logic xHCI USB 3.0 Hub Device Driver - OEM ONLY; none at - FRESCO LOGIC INC.===Leap into SuperSpeed===
http://www.carrona.org/drivers/driver.php?id=FLxHCIh.sys
tap0901.sys Thu Nov 24 13:50:27 2011 (4ECE91F3)
OpenVPN driver or COMODO
http://www.carrona.org/drivers/driver.php?id=tap0901.sys
Analysis:
[font=lucida console]**************************Mon Feb  4 15:06:14.512 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\020513-8938-01.dmp]
Windows 8 Kernel Version 9200 MP (8 procs) Free x64
Built by: [B]9200[/B].16461.amd64fre.win8_gdr.121119-1606
System Uptime:[B]6 days 8:59:58.787[/B]
*** WARNING: Unable to verify timestamp for L1C63x64.sys
*** ERROR: Module load completed but symbols could not be loaded for L1C63x64.sys
Probably caused by :[B]L1C63x64.sys ( L1C63x64+689f )[/B]
BugCheck [B]D1, {0, 2, 0, fffff88004a0689f}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x000000D1]DRIVER_IRQL_NOT_LESS_OR_EQUAL (d1)[/url]
Arguments:
Arg1: 0000000000000000, memory referenced
Arg2: 0000000000000002, IRQL
Arg3: 0000000000000000, value 0 = read operation, 1 = write operation
Arg4: fffff88004a0689f, address which referenced memory
BUGCHECK_STR:  AV
PROCESS_NAME:  System
FAILURE_BUCKET_ID: [B]AV_L1C63x64+689f[/B]
CPUID:        "Intel(R) Core(TM) i7 CPU       X 940  @ 2.13GHz"
MaxSpeed:     2130
CurrentSpeed: [B]2128[/B]
  BIOS Version                  G73Jw.202
  BIOS Release Date             08/05/2010
  Manufacturer                  ASUSTeK Computer Inc.
  Product Name                  G73Jw
**************************Tue Jan 29 06:05:38.498 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012913-11076-01.dmp]
System Uptime:[B]0 days 0:01:45.157[/B]
Probably caused by :[B]L1C63x64.sys ( L1C63x64+61ae )[/B]
BugCheck [B]D1, {18000000428, 2, 0, fffff88003e5e1ae}[/B]
Arguments:
Arg1: 0000018000000428, memory referenced
Arg4: fffff88003e5e1ae, address which referenced memory
BUGCHECK_STR:  AV
FAILURE_BUCKET_ID: [B]AV_L1C63x64+61ae[/B]
MaxSpeed:     2130
  Product Name                  G73Jw
**************************Tue Jan 29 06:03:30.919 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012913-11278-01.dmp]
System Uptime:[B]0 days 0:05:03.578[/B]
*** WARNING: Unable to verify timestamp for athrx.sys
*** ERROR: Module load completed but symbols could not be loaded for athrx.sys
Probably caused by :[B]L1C63x64.sys ( L1C63x64+6b46 )[/B]
BugCheck [B]133, {0, 283, 282, 0}[/B]
BugCheck Info: [url=http://www.carrona.org/bsodindx.html#0x00000133]DPC_WATCHDOG_VIOLATION (133)[/url]
Arguments:
Arg1: 0000000000000000, A single DPC or ISR exceeded its time allotment. The offending
    component can usually be identified with a stack trace.
Arg2: 0000000000000283, The DPC time count (in ticks).
Arg3: 0000000000000282, The DPC time allotment (in ticks).
Arg4: 0000000000000000
BUGCHECK_STR:  0x133
FAILURE_BUCKET_ID: [B]0x133_DPC_L1C63x64+6b46[/B]
MaxSpeed:     2130
  Product Name                  G73Jw
**************************Tue Jan 29 05:57:46.972 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012913-11434-01.dmp]
System Uptime:[B]0 days 0:03:16.630[/B]
Probably caused by :[B]L1C63x64.sys ( L1C63x64+61b2 )[/B]
BugCheck [B]133, {1, 784, 0, 0}[/B]
Arguments:
Arg1: 0000000000000001, The system cumulatively spent an extended period of time at
    DISPATCH_LEVEL or above. The offending component can usually be
Arg2: 0000000000000784, The watchdog period.
BUGCHECK_STR:  0x133
FAILURE_BUCKET_ID: [B]0x133_ISR_L1C63x64+61b2[/B]
MaxSpeed:     2130
  Product Name                  G73Jw
**************************Tue Jan 29 05:50:38.402 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012913-13603-01.dmp]
System Uptime:[B]0 days 0:08:20.060[/B]
BugCheck [B]D1, {0, 2, 0, fffff880043c589f}[/B]
Arguments:
Arg4: fffff880043c589f, address which referenced memory
BUGCHECK_STR:  AV
MaxSpeed:     2130
  Product Name                  G73Jw
**************************Tue Jan 29 05:40:11.720 2013 (UTC - 5:00)**************************
Loading Dump File [C:\Users\Owner\SysnativeBSODApps\012913-13728-01.dmp]
System Uptime:[B]17 days 21:03:37.631[/B]
Probably caused by :[B]L1C63x64.sys ( L1C63x64+61b7 )[/B]
Arguments:
BUGCHECK_STR:  0x133
FAILURE_BUCKET_ID: [B]0x133_ISR_L1C63x64+61b7[/B]
MaxSpeed:     2130
  Product Name                  G73Jw
[/font]
3rd Party Drivers:
[COLOR=RED][B]ATK64AMD.sys                Tue May 12 21:04:54 2009 (4A0A1CB6)[/B][/COLOR]
[COLOR=RED][B]ASMMAP64.sys                Thu Jul  2 05:13:26 2009 (4A4C7A36)[/B][/COLOR]
[COLOR=RED][B]kbfiltr.sys                 Mon Jul 20 05:21:42 2009 (4A643726)[/B][/COLOR]
[COLOR=RED][B]MBfilt64.sys                Thu Jul 30 23:40:32 2009 (4A7267B0)[/B][/COLOR]
[COLOR=RED][B]HECIx64.sys                 Thu Sep 17 15:54:16 2009 (4AB293E8)[/B][/COLOR]
[COLOR=RED][B]FLxHCIc.sys                 Fri Sep 24 07:15:24 2010 (4C9C884C)[/B][/COLOR]
[COLOR=RED][B]FLxHCIh.sys                 Fri Sep 24 07:15:32 2010 (4C9C8854)[/B][/COLOR]
[COLOR=RED][B]tap0901.sys                 Thu Nov 24 13:50:27 2011 (4ECE91F3)[/B][/COLOR]
athrx.sys                   Wed Mar 21 23:26:22 2012 (4F6A9BDE)
RtsPStor.sys                Thu Mar 29 03:09:33 2012 (4F740AAD)
nvhda64v.sys                Tue Jul  3 11:25:04 2012 (4FF30ED0)
L1C63x64.sys                Wed Jul 18 22:54:44 2012 (500776F4)
dump_storahci.sys           Wed Jul 25 22:30:35 2012 (5010ABCB)
idmwfp.sys                  Wed Nov 21 09:42:58 2012 (50ACE872)
nvlddmkm.sys                Fri Nov 30 22:24:02 2012 (50B97852)
RTKVHD64.sys                Tue Dec 18 08:15:57 2012 (50D06C8D)
RTKVHD64.sys                Tue Oct 16 07:33:15 2012 (507D45FB)
[/font]
http://www.carrona.org/drivers/driver.php?id=athrx.sys
http://www.carrona.org/drivers/driver.php?id=RtsPStor.sys
http://www.carrona.org/drivers/driver.php?id=nvhda64v.sys
http://www.carrona.org/drivers/driver.php?id=L1C63x64.sys
http://www.carrona.org/drivers/driver.php?id=dump_storahci.sys
http://www.carrona.org/drivers/driver.php?id=idmwfp.sys
    Win8.1Pro - Finally!!!
    Samsung/NP780
    upgraded to 12 gB from 8 gB
    800x600
    no Mouse - Trackball!!!!
9det
10
Solved. it wasn't the SSD. It was the NIC that was at fault (oddly enough, ONLY when streaming)
Seems like Atheros 8131 drivers aren't there yet as far as Win 8 is concerned.
