Solved Internet Connection but browsers do not work.
2
Hello,
I have just recently installed Windows 8 Pro and have had no problems, except my internet browsers.
I am connected to the internet and can use some programs using it such as skype, but none of my browsers will work. (Internet explorer, Google chrome, Firefox.)
In google chrome i get Error 138, and have researched that and found that it is apparently a problem with your antivirus blocking it, although I have gone into my Bullguard's firewall and allowed all browsers as permitted programs.
I also allowed them all in the computers own control panel. I have also found that another answer to it is unchecking the proxy setting in internet options, although that makes no change.
Can someone else please post another possible solution, I will be happy to answer questions.
Thank you
    Windows 8 Pro
    2.4ghz
    8GB Ram
    AMD Radeon HD 7400M Series
znod
2,156
I would completely disable all third-party security items (AV, malware, and firewall) and let the Win8 security features take over protection for awhile as a test.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Hello,
Thank you
This one has been coming up pretty often lately. Usually just resetting winsock and the TCP/IP stack fixes this problem.
1. Open up the command line utility as Admin and enter each command one at a time :
netsh winsock reset catalog (resets winsock entries)
netsh int ip reset reset.log hit (resets TCP/IP stack)
2. Reboot your PC
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
And I know that worked but the least you can do is report back in. ;)
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
2
znod's solution worked for some bizarre reason, as it was an allowed program in Bullguard anyway. Also even if I disabled Bullguard it would still not work. Happy now it is working, and thank you both.
    Windows 8 Pro
    2.4ghz
    8GB Ram
znod
2,156
Miracles never cease. Glad you got it going. And, you are very welcome.
    EVGA 570 SC
    Gateway
    Dual Boot:
Lkay54
1
Hello,
Thank you
2. Reboot your PC
I just joined so I could sign on and tell you this reset worked for me the first time. I really appreciate the efforts of people who share this type of information. Well done!
#8
Thanks for signing up and reporting back in Lkay54. Common problem and easy enough to fix. The diagnoses is sometimes the tricky part.
This thread now has 7,294 hits so maybe it's helped others as well. :party:
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
my2cents
Veni, Vidi, Vici
2,191
#9
Yes, and you have helped thousands of others over time so keep up the great work here!
You are an expert in your field!
Best regards,
my2cents
    Intel G2020
    ASRock B75M-DGS R2.0
    8GBs @ 1333 MHz
    Samsung 840 EVO
    400w
1
#11
Hey just like in the main thread I can use skype (but I can't see the skype home) and I can see my friends who are online but can't go into store or anything else and no browser will work I have tried all the methods listed but nothing has worked, please help would be appreciated
jobu
I have a Toshiba Satellite laptop that has had this issue in the past. Previously, I was able to correct the browser problem using the methods outlined by Chev65. This time, after restarting the laptop, the browser works for about a minute.... then nothing. All Win8 tiles continue to update so I have internet connectivity. Malware scan came up clean. Any thoughts?
    Win 8.1
    Toshiba Satellite L855
jobu
As an additional observation, safe mode with networking "cures" the problem. Regular rebooting generates the symptom (no browser functionality -- IE or Firefox) again.
    Win 8.1
Ztruker
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    [email protected]
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
jobu
In my case, Ztruker's post led me to disabling the Norton Suite which was apparently factory installed. Disabling cured the issue.
    Win 8.1
Ztruker
Good going, glad you got it fixed.
I'd suggest uninstalling Norton completely (download the Norton Removal Tool) then use the built in Windows Defender or one of the other free AV programs but not McAfee.
    Windows 10 Pro X64
    Lenovo
    Realtek HD Audio
    HP h2207
    [email protected]
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    UEFI/GPT
