Solved Intel Management Engine Interface Problem
SaggyMaggyPoo
Greece
341
In Device Manager I have an ! against Intel Management Engine Interface.
In Driver Properties it says:
This device cannot start. (Code 10)
An invalid parameter was passed to a service or function.
I have also seen errors related to this in a recent Perfmon report.
I have tried to update the driver (right click on it in Device Manager, check on Dell website, check with Intel Driver Update Utility) but all these methods say I have the up to date one.
On my other Dell laptop (same spec) the same version of this is running without a problem. On that laptop there was an update in mid November that I don't have on the problem laptop. I have a feeling that I did a System Restore back around that time that affected a few things, and this may have been one of them. I thought I had kept a screenshot of this, but must have deleted it so I can't be sure:(.
Question is: how can I get this working again?
Should I try uninstalling and reinstalling it?
If so, what is the best (and most foolproof) way to do this? Can I do it from the right click options in Device Manager, for example? I'm a bit concerned that, if I uninstall it I may not get the correct version back again:(.
    Win8.1 64bit, Windows 10 TP on VMWare Player
    Dell Inspiron 15 3521
    1.80 gigahertz Intel Core i5-3337U
    Dell Inc. 0010T1 A00
    8gb
    Intel HD Graphics 4000
    Realtek HD Audio & Intel Display Audio
    TOSHIBA MQ01ABD050 [Hard drive] (500.11 GB)
    Additional fan
    Kensington Trackball
    IE
    Emsisoft Internet Security, Malwarebytes free & antiexploit
KYHI
2,756
yes uninstall the driver until you get the ? mark for unknown device, reboot and reinstall the driver
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
SaggyMaggyPoo
Greece
341
Thanks for this, KYHI.
As I'm not very technical can I just clarify:
  • will I get the ? for unknown device as part of the process of uninstalling using the right click?
  • and from where do I reinstall the driver?
I prefer to know what I'm going to encounter before I start down an unfamiliar road whenever possible :).
    8gb
    Additional fan
    IE
KYHI
2,756
properties - uninstall driver
download dell driver (extract) then click unknown device - update driver - browse - point to extracted dell driver ( this will load the driver only) not the app.. if you want the whole app - run the dell driver setup
    Dell XPS 8700
    I7
    24 GB
SaggyMaggyPoo
Greece
341
Thanks for the clarification KYHI. Will have a go at this in the next few days and see if it does the trick.
    8gb
    Additional fan
    IE
SaggyMaggyPoo
Greece
341
Just uninstalled, which was slightly disconcerting as it installed the device as well as the driver.
Rebooted and reinstalled and now I have a properly working driver again :dinesh:.
Another one to tick off the list.
Thank you KYHI :thumb:
    8gb
    Additional fan
    IE
