Intel Management Engine inteface driver
Tully
Dublin, Ireland
331
I have been going crazy try to update my ASUS H81M-PLUS motherboard BIOS.
ASUS is no help. Intel is no help.
This might not be the right forum for this, but,
I reached a point in the BIOS update (complicated) process where it now wants me to download the following driver
for an Intel 4gen processor; (I5);
Intel management engine interface driver!
can't go any further without this driver!
Can't find it! Can't find anywhere to get more info
Help
Tully:cry:
    Win 10 Beta
    Home Assembled
    Intel I5
    ASUS P8Z&&-V LX
    8 GB DDR2 SDRAM
    Intel on board
    INTEL ON MB
    Samsung TD390 HDMI
    1920 X 1080
    Crucial MX100 512GB SSD
    2TB Storage
    External Seagate "Dashboard" File Backup Drive USB3
    WD "My Cloud" 4TB
    Samsung Super Write Master 24 DVD Writer
    Cosair
    Corsair
    AIR
    Advent USB Keyboard
    Advent USB
    200 MB dwn 30MB up
    IE 11 Win 10
    MS Essentials
    USB2 & USB3
mikolajek
Warsaw, Poland
65
Truly? Have you visited Intel Download Center and searched for this? Here's the link to the search engine results: Intel Download Center.
All you need to do is to select your MoBo or - more general and easier ;) - your chipset generation.
    Windows 8.1 Pro x64
    Dell Precision M4800
    Intel i7-4900MQ
    32 GB
    Intel HD Graphics 4600 & nVidia Quadro K2100M
    Dell U2312HM & Dell 2408WFP
    1920x1080 & 1920x1200
    Samsung 840 EVO 256 GB & Hitachi TravelStar 5K750 750 GB
    Firefox 32
    Kaspersky Internet Security 15
Tully
Dublin, Ireland
331
Truly?
Followed your suggestion & went to the Intel site found the Intel management engine interface driver.
Tried to download it & said I had to download a Java Program first ?? What Java Program from where.
Another step in a vicious circle.
It seems to me that in this age of computer technology Asustek, Intel, Microsoft should have provided a simple means of updating the BIOS on a motherboard.
I can remember in LESS technical times when updating a BIOS was a simple task.
The computer industry should concentrate on this problem instead of creating another useless "FEATURE"
The Old Fart
Tully
    Win 10 Beta
    Home Assembled
    Intel I5
    ASUS P8Z&&-V LX
    8 GB DDR2 SDRAM
    Intel on board
    INTEL ON MB
    Samsung TD390 HDMI
    1920 X 1080
    2TB Storage
    WD "My Cloud" 4TB
    Cosair
    Corsair
    AIR
    Advent USB Keyboard
    Advent USB
    200 MB dwn 30MB up
    IE 11 Win 10
    MS Essentials
    USB2 & USB3
CountMike
Belgrade , Serbia
4,664
On most older MBs there was a way to update/upgrade BIOS version thru BIOS itself, that is not OS function, it's firmware written directly into BIOS chip. It's more complicated with UEFI bios updates. As far as I can see there's "H81M-PLUS BIOS 2001 and BIOS updater" program here : https://www.asus.com/Motherboards/H81MPLUS/HelpDesk_Download/ is that the one you were using / trying to find ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
mikolajek
Warsaw, Poland
65
Hmmm... That's strange as I have a fresh system install and have not installed Java so far. At the same time I had no problem with download the mentioned driver (just tested that).
However if you are willing to get Java (it's also useful for other purposes), just download latest build from here - you'll need 32-bit version unless you're using 64-bit browser.
    Windows 8.1 Pro x64
    Intel i7-4900MQ
    32 GB
    Firefox 32
topgundcp
San Jose - California
2,847
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
Tully
Dublin, Ireland
331
Bios update
I sat down & analysed the situation;
1. I was already running Win 8.1 why would they recommend the download before the BIOS update?
2. I started all over again, I downloaded the only BIOS update on the ASUS site that DID Not demand the update.
3. Put the BIOS on a thumb drive.
4. Went into the ASUS setup screen for BIOS update.
5. Selected the thumb drive, It installed the new BIOS, held my breath!
6. When it finished, I restated & IT WORKED!
7 Problem solved!
Thanks for all the help!
Tully
    Win 10 Beta
    Home Assembled
    Intel I5
    ASUS P8Z&&-V LX
    8 GB DDR2 SDRAM
    Intel on board
    INTEL ON MB
    Samsung TD390 HDMI
    1920 X 1080
    2TB Storage
    WD "My Cloud" 4TB
    Cosair
    Corsair
    AIR
    Advent USB Keyboard
    Advent USB
    200 MB dwn 30MB up
    IE 11 Win 10
    MS Essentials
    USB2 & USB3
