Installing Windows 8 Pro in 64 bit mode on a XP Pro 32 bit
steadyeddie2
[FONT=Arial, Helvetica, sans-serif] I down loaded W-8 Pro to a Windows XP Pro unit with 8 GB Ram and a E6300 2.8 GHz CPU (64 bit capable and Gigabyte EP45T - UD3 LD MB. I was hoping for the 64 bit install and got the 32 bit install. I was told that by using my 64 bit W-8 install disk I could upgrade to 64 bit, but can't. The XP system was 32 bit, but the CPU and MB should handle 64 bit. Since the system mode was 32 bit how to I get a 64 bit install?. The MS support technical contractor was no help.[/FONT]
You can't upgrade a 32-bit OS with a 64-bit OS. The only way out will be, to boot from your Windows-8-DVD / USB-Stick and do a clean installation.
If you have trouble to get Windows-8 activated afterwards, then you can try this here:
1.) Just install Windows-8 again over the already installed Windows-8 and activate it after
or
2.) Do the following:
Change this registry key:
HKEY_LOCAL_MACHINE/Software/Microsoft/Windows/CurrentVersion/Setup/OOBE
Change "MediaBootInstall" from "1" to "0"
After doing that, typed "slmgr /rearm" (without the " ") into a command prompt (right-click, Run as Admin), wait for conformation prompt, restart your pc and activate Windows-8.
Uploaded with ImageShack.us
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
or
Or you can do this:
http://www.eightforums.com/tutorials/13375-clean-install-windows-8-upgrade.html
    Windows 10 Pro x64
    Lenovo Y520
    Intel Core i5 7300HQ
    OEM Lenovo
    4GB DDR4-2400
    NVIDIA GeForce GTX 1050
    Realtek HD
    Seagate 1TB 5400 RPM
    OEM Lenovo
    Logitech G502 Proteus Core
    100 Mbps
    PC:
    AMD Athlon X4 760K
    8GB DDR3-1866
    AMD Radeon RX 460
    Seagate 500 GB 7200 RPM
The Win8 upgrade link will not download a 64-bit OS to a computer running 32 bit regardless of having 64 bit capability. If you want 64 bit, then one alternative is to install a legal older 64-bit Win OS and download a new upgrade. Be sure and use the option of downloading the ISO so you can make an install DVD in place or later (or make a USB flash drive installer later). You also might consider purchasing and installing the 64-bit OEM Win8 System Builder version under the personal use license. While it may not sound like it, those in the know argue that anyone qualifies for using this version on one owned computer/installation at a time.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
Hi there
To see if you actually like Windows 8 first why don't you download the FREE trial of Windows 8 Enterprise 64 bit and install it as a Virtual machine on your XP system.
Actually I see you already have a copy of W8 x-64 -- so install that as a VM first to see if you like it and if the programs you need from XP will still run.
A 32 Bit HOST OS CAN RUN A 64 BIT GUEST Virtual Machine provided you enable the virtualisation VT feature in the BIOS (it's usually automatically enabled in modern machines now).
Use free VMware vmplayer or oracle's free VBOX for creating your virtual machine -- even the X-64 W8 Enterprise will run quite nicely on a 1GB virtual machine !!. 2GB is better of course or even more -- but your XP host is of course limited to 4GB anyway.
Then if you don't like W8 you can upgrade to W7 -- although again for installing a 64 bit version when your original OS is a 32 bit one you'll have to do a Fresh install.
In any case before doing ANYTHING backup your XP system so if things go pear shaped you can recover your old system while working on solutions.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
I never do an upgrade, I learned from experience.
The MS drivers are tuned for speed and stability, but their lawyers rule the roost since Bill left, so their drivers are always crippled as to not infringe on anything that might make money down the rode. Thus hobbled audio and no UAC2 support...
If they don't include UAC2 support 8 will fail miserably. They underestimate the global consciousness.
As do all machines.
Multi channel audio recordings are going to be the big thing again, I think they are missing the point again.
You can create multi channel audio and completely avoid patent infringements.
Perhaps it's an expertise problem?
pear shaped...hahahaha! cheers!
There is only like 3% of the people in the world that even understand that joke.
    Windows 8 Ent
    rebranded japan - hp oem
    A8-3555MX FS1 socket
    8gb
    Sumo UMA
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
