Installed TrueCrypt and password already exists...
btowngurl1974
So recently I decided to 'encrypt' my drives for extra safety. I installed TrueCrypt, and began messing with it. I tried to encrypt, or create a new drive, and it asked for a password. Hmmm...does this mean someone else is already using it on my drive?
    Dell Inspiron 15 3521
    Intel Core i3-3227U CPU 1.90GHz
    EUFI
    4.00 GB
    Intel HD Graphics 4000
    Name High Definition Audio Device
    Name Intel(R) HD Graphics 4000
    Resolution 1366 x 768 x 60 hertz
    Manufacturer (Standard disk drives)
    Model ST500LT012-9WS142
    Media Type Fixed hard disk
    Description Disk drive
    Model SanDisk Cruzer Glide USB Device
    Description Standard PS/2 Keyboard
    Hardware Type Dell Touchpad
    IE11
    Windows Defender and Norton 360
    1394ohci 1394 OHCI Compliant Host Controller c:\windows\system32\drivers\1394ohci.sys Kernel Driver No Manual Stopped OK Normal No No
    3ware 3ware c:\windows\system32\drivers\3ware.sys Kernel Driver No Manual Stopped OK Normal No No
    acpi Microsoft ACPI Driver c:\windows\system32\drivers\acpi.sys Kernel Driver Yes Boot Running OK Critical No Yes
    acpiex Microsoft ACPIEx Driver c:\windows\system32\dri
mikeytg
If it is going to encrypt something it needs you to enter the password you want to use first. You should carefully read the truecrypt documentation before you start encrypting stuff. It would be wise to have a complete image backup of your system stashed away before you start. Keep in mind that Truecrypt has been abandoned so there will be zero support if anything goes wrong.
    Windows 8.1 consumer 64 bit
    Acer Aspire M5 481PT-6644
    Intel Core I5
    6 GB
    ELAN Trackpad
    18mbs/5mbs
    Chrome
btowngurl1974
Thanks for that advice. I thought I understood the rules, as I did go over the documentation page, in which mostly was about the fact that they were shut down. However, when my drives are partitioned in the incorrect format for the software anyway. Apparently, you can 'create' a new 'folder' within a drive that is password encrypted, but my actual drives are not in their compatible format. Maybe that's why I've had issues with data recovery all along?! I I'm having a hard time trying to get my computer back to normal due to someone I know who has embedded so many drivers, some hidden, and has somehow tricked my computer. About a day after doing a fresh install, this person was attempting to play a PC game, "Helicopter Rescue", or something and asked me to see if it would play in my computer. I was extremely hesitant as I had JUST spent five days repairing it via win8 forums and trial and error. Since then, all went terribly wrong and I began seeing files on my C drive that were from last year, when I had just wiped it clean. And then I kept getting unauthorized remote access (caught it running in services, twice), but it's not ticked in control panel or in programs. Anyway, maybe I'm over paranoid, but this is the second install, first 'clean' one within a months timeframe and it's been more than irritating. I'm tired of playing their game of cat and mouse. I will leave true crypt well enough alone, and uninstall promptly. Thank you!! Solved!
    EUFI
    4.00 GB
    IE11
KYHI
Question - are you working on PC's ??
You seem to be posting a lot of different pc issues..
are they all from the same pc???
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
jds63
    Windows 10 Pro 64bit
    Gigabyte GA-X99-UD3
    1920x1200 16:10
    AZZA Cosmas Black Gaming Case
    84mbps /94mbps
    Norton Security 2015
