Solved Installed Intel Rapid Storage now Recycle Bin error
fohrums
-Windows 8.1 Professional x64
-I have (2) HDD's under RAID 1 {mirrored}
After fresh install I now have the (2) HDD's shown and was was notified to install chipset driver, so I did and ended up installing the Intel Rapid Storage Technology.
Now my (2) HDD's are mirrored {combined to one drive} but the problem is I get an error about recycle bin being corrupt, delete- yes or no?.... and nothing works trying both options and the message keeps coming up.
    Win8
fohrums
** problem was a corruption with my RAID 1 config between two of my drives for windows to see it as (1) drive.
it happened when I changed my drive type in BIOS from RAID to AHCI. You shouldn't do this as it will leave you with a corrupted windows install as it doesn't know how your drives are configured.
PREVENTION: don't change drive type in BIOS when you still have an operating OS installed.
    Win8
HBHB
you can change settings in BIOS.However must restart on safe mode,then back on regular start up. Windows installs the right driver automatically. Done on Asus .
    Win8.1 64 bits Ent- Pro
    Asus
    Intel 3000-Radeo hd 6370- Nvidia Ge540
MaXimus
Once Windows is installed, the rule is, you should never change the boot from AHCI to RAID or vice versa in BIOS or you will render you Windows not bootable.
On my Alienware 18 laptop, if I do try to change from AHCI to RAID or vice versa, I get a big black popup warning telling me that this could render my system not bootable
Additionally, if you are using RAID 1, why in the world did you want to switch to AHCI? doesn't make sense (no offense)
    ALIENWARE 18 Laptop
    Intel Core i7-4940MX Extreme CPU @ 4 GHz
    Alienware 0FT9KT
    32 GB Kingston HyperX 1866MHz DDR3 PC3-14900 RAM
    Dual GeForce GTX 780M SLI 2x4GB GDDR5 RAM
    Realtek ALC668 HD Audio
    Dell 18.4" WLED FHD (1920 X 1080) TrueLife Display IPS 16:9 1080p [SDC4C48]
    2x SanDisk Extreme PRO 960GB SSDs + 850 EVO 1TB mSATA SSD
    Alienware TactX Keyboard
    Logitech G602 Wireless Gaming Mouse
    50 MBPS Download / 10 MBPS Upload
    ESET NOD32 Antivirus
fohrums
why in the world did you want to switch to AHCI? doesn't make sense.
In the land of computing (probably reasons why I go to this forum anyways) there is mostly or only informal learning (the problem with the world today).
It's like this: I don't know what cache is or speed by ghz but I know what the best CPU to get based on reviews and price. YAY to informal learning.
    Win8
popeye
I don't care for Intel Rapid Storage. Have installed it several times and end up deleting it. Caused weird problems.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
