Installation Problem : Select Partition
arielxarg
hello , i got a little problem here when i want to install windows 8 dual boot with windows 7
when i must select the partitions , it always error and say :
Windows cannot be installed to this hard disk space. The partitions contains one or more dynamic volumes that are not supported for the installation. The selected disk has the maximum number of partitions of this type.
here's the screenshot of my storage.
    Windows 8.1 Pro 64-Bit
    Asus X450CC
    Intel Core i3 3217U
    2GB
    Nvidia GT720M
    1366x768
    500GB + Toshiba 1TB External
    Leopold FC500RR
    Mionix Naos 5000
    1Mbps
    Avast!
hello , i got a little problem here when i want to install windows 8 dual boot with windows 7 :(
Hello Arielxarg, and welcome to Eight Forums.
The problem is that your Disk 0 HDD had been converted to be a dynamic disk. Most likely this was done by mistake when shrinking the C: drive for the 56.61 GB unallocated space partition.
You would need to extend the C: partition back in the unallocated space, then use OPTION FOUR to convert the disk back to being a basic disk.
http://www.sevenforums.com/tutorials/26829-convert-dynamic-disk-basic-disk.html
Unfortunately, your disk already has 4 primary partitions, and will not be able to create another one on it to install Windows 8 without affecting your factory recovery partitions. :(
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
arielxarg
Convert a Dynamic Disk to a Basic Disk - Windows 7 Forums
thanks for the response :)
ahh too bad :(
then what must i do to install windows 8 then ? :confused:
    Asus X450CC
    Intel Core i3 3217U
    2GB
    Nvidia GT720M
    1366x768
    Leopold FC500RR
    Mionix Naos 5000
    1Mbps
    Avast!
Pooch
    Windows 7 and Windows Developer Dual efi boot
    Home Brew
    Intel Core i7-2600K
    Asus P8P67
    16 GB G Skill F3-10666 CL9D-4GBRL
    ATI Radeon HD 6870
    ATI Radeon HDMI / Realtek ALC892
    2 x 22" standard monitors / LG32LC56 to watch films
    1920 x1080
    2 x OCZ Vertex2 120GB in RAID 0
    3 x Samsung103SJ
    1 x Samsung103UJ
    1 x WD3200BEVT
    1 x Hitachi5K320-160
    Thermaltake Toughpower Cable Management 750W
    Antec 300
    Noctua NH-U12P SE2 and 5 120mm Case fans
    Microsoft Comfort Curve Keyboard 2000
    Hama M3110 / Logitech M305
    I have also used Fedora, Suse, Ubuntu Linux
    And all other Windows from 95 to date except ME
    Lumia 1520 phone
whs
One other option is that you use the bootable CD of Partition Wizard (last entry on the webpage). Burn this .iso to a CD and load from the CD. Then set your Windows7 C: partition as logical (controls are under the Partition Tab > Modify). That frees one of your primary partition and you now can create additional logical partitions.
    Vista and Win7
    5 SSDs and 12 HDs
whs
Yeah, you fell into the classic trap - In NTFS you can only have 4 primary partitions or 3 primaries and one extended under which you can create many new partitions.
You have to first reconvert your dynamic partitions to basic partitions. Convert a Dynamic Disk to a Basic Disk - Windows 7 Forums
Then you have to convert one of your primary partitions to a logical partition. Best candidate is probably your C: partition. You do that with the bootable CD of Partition Wizard (last entry on the webpage). Burn that .iso to a CD and load it from the CD reader. The controls you need are under the Partition tab > Modify.
Once this is all settled, you can create your additional partition - and do not make that a primary. The OS can very well reside on a logical partiton as long as it is not active.
    Vista and Win7
    5 SSDs and 12 HDs
arielxarg
thanks for the advice guys , finally i can proceed until the installation ( i use VHD ) , but there's another problem :confused:
there's an error "Windows could not update the computer's boot configuration. Installation cannot proceed." :rolleyes:
    Asus X450CC
    Intel Core i3 3217U
    2GB
    Nvidia GT720M
    1366x768
    Leopold FC500RR
    Mionix Naos 5000
    1Mbps
    Avast!
Pooch
arielxarg Please disregard this post I wrote it before I realised what you are trying to do
( i use VHD )
Strange:shock:
Have a look at this; 'Windows could not update boot configuration' - FIX It is for Vista but may still work for you.
use these tutorials to help; http://www.eightforums.com/tutorials/2269-system-recovery-options-boot-windows-8-a.html Option 2
http://www.eightforums.com/tutorials/2843-automatic-repair-run-windows-8-a.html
    Home Brew
    Intel Core i7-2600K
    Asus P8P67
    ATI Radeon HD 6870
    1920 x1080
    3 x Samsung103SJ
    1 x Samsung103UJ
    1 x WD3200BEVT
    Antec 300
whs
    Vista and Win7
    5 SSDs and 12 HDs
Originally Posted by arielxarg
( i use VHD )
That is interesting. I have seen booting from VHD, but how does one install from a VHD - and why.
Hello Wolfgang,
It's spin off that one, but you would create the VHD file at boot and install Windows to the VHD at boot instead. It's handy if you didn't already have an existing VHD file to use, or you wanted to use a VHD instead of the usual dual boot to be able to say mount the VHD as a drive another installed OS as well. A VHD just gives you a bit more flexibility of how you can use it verses a normal installation.
Virtual Hard Drive VHD File - Create and Start with at Boot - Windows 7 Forums
    Lumia 1520 phone
whs
Thank you Shawn for the clarification. I had studied your tutorial about booting from a VHD. But here I was confused because the OP seems to suggest that one can install from a VHD. It is probably just a matter of wording that confused me.
    Vista and Win7
    5 SSDs and 12 HDs
Yeah, I wasn't to sure about that either, and guess that's what the OP may have meant.
    Lumia 1520 phone
whs
Btw: One can image a VHD and then restore the image. That would be one way to use a VHD as basis for an installation.
    Vista and Win7
    5 SSDs and 12 HDs
Yes, indeed. A VHD is much more versatile. :)
    Lumia 1520 phone
aem
I'm not a fan of VHD usage unless it's for testing and or when your native hardware is limited in some way.
    CP
