Install on GPT disk and System Reserve questions
1
Hi, I am wondering if it is the same procedure to install Windows 8 consumer preview on a GPT formatted disk as it is in Windows 7.
In Windows 7 GPT I just need to make the 3 partitions: EFI, MSR, and the Storage.
But in Windows 8 there is an extra partition when installed on a GPT disk by default, a Recovery partition.
What is the Recovery partition for?
How can I make the recovery partition in diskpart with 4k offset?
Like:
Type Create Partition <name of recovery partition> Size=300 Align=4096, press Enter
Type Format Quick FS=NTFS, press Enter
This is what I have so far without the recovery partition.
  1. Type Diskpart, press Enter
  2. Type List Disk , press Enter
  3. Type Select Disk # (where # is the number your drive shows up as), press Enter
  4. Type Clean, press Enter
  5. Type Convert GPT, press Enter
  6. <waiting for recovery partition info>
  7. <waiting for recovery partition info>
  8. Type Create Partition EFI Size=100, press Enter
  9. Type Format Quick FS=FAT32, press Enter
  10. Type Create Partition MSR Size=128, press Enter
  11. Type Create Partition Primary, press Enter
  12. Type Format Quick FS=NTFS, press Enter
  13. Type Exit, press Enter
Also, what is the downfalls of not creating the system reserve partition for Windows 8 in general? I know in windows 7 it was just a back up of the boot files and needed for bit-locker and dynamic disks or something, is it the same as windows 7 or is there more? What is it used for exactly in Windows 8?
Thanks :D
    Windows 7 Pro 64-bit, Windows 8 Consumer Preview 64-bit
    i5 2500K @5GHz
    Asus P8Z68-V
    8GB G.Skill Ripjaws X
    Asus Xonar DX
    Samsung P2370HD, HPw1907
    1920x1080, 1440x900
    128GB Plextor M3, 64GB Crucial M4, 1TB Samsung Spinpoint F3
    Corsair TX650
    Corsair 650D
    Thermalright Silver Arrow
    Logitech K120
    Logitech V220 Blue
    2MB/s Down, .3MB/s Up
1,851
Not sure at all because I never played around with that ever, but my guess is the 300 MB recovery partition is the "system" partition where Windows installs its boot files (bootmgr) and folder (holding bcd).
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
