imageres.dll problem
gabyel1811
Hello everyone..can somebody help me with my problem?? I was trying to modify the system file "imageres.dll"..The thing is, i want to replace it with a modified "imageres.dll" from desktop to its place but it was always saying that it can't be replaced because its open..So, wath i think would work is that, i renamed the ORIGINAL "imageres.dll" to "imageres2.dll" and then copied the modified "imageres.dll" from the desktop to "C:\Windows\System32" and then tried to delete the ORIGINAL "imageres.dll" which was renamed to "imageres2.dll"..And then VOILA! theres nothing happening, the modified "imageres.dll" from desktop wasn't there and the ORIGINAL "imageres.dll" (imageres2.dll) file is still there and can't be deleted! Now i'm having problem with this cause when i try to open Control Panel, nothing's shown! i still don't know what else goes wrong but i'm really alarmed about my Control Panel being '"blanked"! Please somebody help me..i'm really regreting what i've done now :cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry::cry:
    Windows 8 Pro 64-bit
caperjack
Just the Janitor
imageres2.dl
so change the name back to imageres.dll, that was part of the reason why you changed the name correct ,so you still had the file in case something happened
    win8.1.1 enterprise
    Name
    jack
    Hinze57
    AMD FX 6100 6core 3.30gHz
    gigibyte ga-78lmy-s2p
    4gig ddr3
    Radon hd5000 Series
    onboard realtek hd
    19" viewsonic/ 22"Samsung
    1680x1050
    128gig ssd Kingston
    80gig WD 10000 rpm spinner
    Occupation
    janitor/maintenece
    micro
    microsoft curve 200
    Logitech wireless M215
    high speed 20
    ie 11
    windows defender
    updated enterprise apr 2/14
    Country Flag
    Canada
    State/Region Flag
    ca novia scotia
fafhrd
Active Member
Doesn't SFC /scannow replace missing or damaged system files? Run the system file checker from a command prompt as admin.
There's more copies of imageres.dll (and imageres.dll.mui) in the \Windows\WinSXS\ folder:
There are different versions for each of X86 and X64 and they are not interchangeable, so don't go messing with them, without due caution. (I don't know if that's true or not, they are both the same size.)
    HP COMPAQ Presario CQ57
    inbuilt
    4GB
    ATI
    notebook
    1366x768
    Seagate ST9500325AS
    Google drive 15GB
    Skydrive 25GB
    BT Cloud
    external 20v
    pretty good
    inbuilt
    touchpad
    Chrome Canary usually
    no Start menu modifications
    Country Flag
    UK
    State/Region Flag
    uk mercia
gabyel1811
I cant run cmd as admin..It acts like nothings happening..i can only run cmd normally but when i try to run it as admin, nothing happening or seems like it was disabled or something :( :( :(
