I'm using 8.1 and I want to delete my D partition with a USERS folder in it
Sidneysnake
How do I delete D so I can extend my C drive? Windows will not allow me to DELETE D as it has a 'USERS' folder in it. The message I get is 'a file or folder is being used in another location, I did not create the USERS folder in D. There is another USERS folder in C.
    windows 8.1
    Toshiba
    8 Gb
starvinmarvin
First, run a full anti-virus scan on all drives.
Next, make sure you're using an Administrator account.
Open drive D:
Open the Users folder.
Open each sub-folder. Move all data that you want to keep to similarly named User folders on drive C:
Check for any other wanted data on drive D: and move it to drive C:
Try deleting the drive D: Users folder, then delete drive D:
    windows 8.1
    custom
    Intel Core i5-4590 @ 3.3GHz
    ASRock Z97 Extreme4
    4 x 4GB G.Skill DDR4-2400
    Gigabyte GTX-1050Ti
Sidneysnake
Thank you for your reply, the problem I have is Windows won't allow me to move or delete the USER folders in D because it keeps saying a folder or file is being used in another program.
    windows 8.1
    Toshiba
    8 Gb
starvinmarvin
Here's something to try. Also, please note that there are other tutorials shown in the list on the right-hand side of the page:
    windows 8.1
    custom
    ASRock Z97 Extreme4
    Gigabyte GTX-1050Ti
Sidneysnake
Thank you for your support really appreciate it. I think the issue may be that iCloud is running in users in D: but this is a guess at the moment.
    windows 8.1
    Toshiba
    8 Gb
TechnoMage
Active Member
Not every day, but fairly often, I will want to take some space from my #2 partition and add it to my #1 (main or C partition, on my main HD.
For years, I've had the EaseUS Partition Master program, and I use that for all my partition work. (I even use it for formatting and partitioning a brand new HD)
First I would resize my second partition to free up some space, then I would add that free space to my C: partition. As long as I perform the task in an orderly manner, Step by Step, I've never had it fail.
Just a suggestion.
TM :cool:
    Win-8.1/Pro/64
    Home Made
    AMD 8 Core
    Gigabyte, Ultra Durable, GA-970A-DSP3
    Crucial, 8GB
    AMD Radeon HD 5450 (2 GB)
    On Board
    24" LG
    Sandisk, SSD 120GB, 8TB Seagate backup drive
    Antec Earthwatts, 650
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
TechnoMage
Active Member
JFWIW....
It's always a good idea, to have a second partition on a single Hard Drive PC, just for a place to keep your valuables, in case the C: partition gets corrupted and you can't access it.
I have several folders on my second partition, with shortcuts to them on my Desktop.
That gives me quick access to things I might want to get to, but don't want taking up valuable real estate on my C: drive.
It's an old habit that goes all the way back to my DOS days.
Be well, and stay safe,
:cool:
    Win-8.1/Pro/64
    Home Made
    AMD 8 Core
    Crucial, 8GB
    On Board
    24" LG
    Pac-Man Case
    HP Professional
    GearHead Wireless
    5 Meg
