IE11 and Enable Protected mode I need OFF for 1 Site
jimbo45
Hi there
WHY MS do you have to make Enable protected mode an all or nothing setting
I have a Media server that needs to open 127.0.0.1:9000 but this fails unless I turn OFF enable protected mode
All I need is for this site (local host at 127.0.0.1) to be an exception.
Anybody know if this is possible to do. (IE11 in Windows 8.1)
The program is actually Logitech Media server -- works fine normally until IE11 had this thing about Protected mode.
Before I found the trick I did all sorts of things like disabling IPV6 (registry entry needed) etc to no avail --kept getting couldn't access the site !!! (localhost !!!!).
If you really need to disable ipv6 in Windows 8 / 8.1 then do it this way
Techunboxed: How to Disable IPv6 in Windows 8
I've reset the system back to enabling ipv6 as well and switching off compatibility view for that site.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
Dwarf
The Contemplator, (1963-2013)
Moderator
Have you tried the Trusted Sites zone for this? Enable Protected Mode can be independently set for each of the 4 zones.
    Windows 8.1 Pro RTM x64
    Dwarf Dwf/11/2012 r09/2013
    Intel Core-i5-3570K 4-core @ 3.4GHz (Ivy Bridge) (OC 4.2GHz)
    ASRock Z77 Extreme4-M
    4 x 4GB DDR3-1600 Corsair Vengeance CMZ8GX3M2A1600C9B (16GB)
    MSI GeForce GTX770 Gaming OC 2GB
    Realtek High Definition on board solution (ALC 898)
    ViewSonic VA1912w Widescreen
    1440x900
    OCZ Agility 3 120GB SATA III x2 (RAID 0)
    Samsung HD501LJ 500GB SATA II x2
    Hitachi HDS721010CLA332 1TB SATA II
    Iomega 1.5TB Ext USB 2.0
    WD 2.0TB Ext USB 3.0
    XFX Pro Series 850W Semi-Modular
    Gigabyte IF233
    1 x 120mm Front Inlet 1 x 120mm Rear Exhaust
    Microsoft Comfort Curve Keyboard 3000 (USB)
    Microsoft Comfort Mouse 3000 for Business (USB)
    NetGear DG834Gv3 ADSL Modem/Router (Ethernet) ~4.0 Mb/sec (O2)
    IE 11
    Avast! 8.0.1497 MalwareBytes 1.75.0.1300
    Optical Drive: HL-DT-ST BD-RE BH10LS30 SATA Bluray
    Lexmark S305 Printer/Scanner/Copier (USB)
    WEI Score: 8.1/8.1/8.5/8.5/8.25
    Asus Eee PC 1011PX Netbook (Windows 7 x86 Starter)
jimbo45
Hi there
That might be an idea -- I'm going to the pub now -- Friday night boozeup in central Reykjavik always a bit lively. Will try tomorrow
Thanks for the suggestion
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
WiFi Ed
I had a similar problem with my media server (Plex) and IE 11 so I added 127.0.0.1 to my trusted sites. It works fine now!
    Windows 8.1 Pro x64
    Dell E520
    Intel Q6700 Core 2 Quad - 2.66 GHz
    Whatever Dell put in there...
    8 GB Mushkin 800 MHz DDR2
    NVIDIA GTX 650 - 2 GB GDDR5
    Integrated
    2 x 19" ViewSonic LCD's
    2560 x 1024
    1 Intel X25-M 120G SSD, 2 WD RE4 2TB HD's
    PCPower & Cooling Silencer 500 Watt
    100/10 Time Warner Cable
jimbo45
Hi there
yes that's fine
guess I never bothered with IE security settings in the past -- but there's a whole new "Cyber crime" industry out there now - these things weren't even in the realms of SCIENCE FICTION when I first started using computers. !!!
BTW if you use SILVERLIGHT then all bets are off -- DOES NOT WORK.
Cheers
jimbo
    1 X LG 40 inch TV
    2 X 3 TB sata
    5 X 1 TB sata
    0.12 GB/s (120Mb/s)
