Solved IDT hd audio not working
Hopachi
Polyhedric Stellation
Just a question:
Has anyone found decent drivers compatible with Win8, that work, for the IDT high definition audio on HP pavilion DV7 laptops?
Thanks
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
GMan
Banned
Find your hardware id string for it in device manager then put it in this website. Use the one with unique subsys string, of the 4. Leave out the revision part. Usually 2nd string down from top.
(Properties | Details tab | Change dropdown to say Hardware ids)
The larger drivers with the same date as smaller are x64. Smaller are x86.
Microsoft Update Catalog
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hopachi
Amazing!
Never expected to work this well.
Thanks GMan for the great solutions.
Cheers
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
GMan
Banned
You're welcome. Gotta have audio!
    P4 3.4 GHz HT
    MSI-7211
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Ojeg
hi, I have a similar problem: No sound on Windows 8 pro (9200) installed on hp 620.
Sound card: IDT High Definition Audio.
Pls help
    HP
    INTEL
Hopachi
Pls help
See the procedure in the posts above first. That seems to be the best solution for LATEST drivers.
We both have HP's and if the MS catalog doesn't have any drivers (brand new models), then you'll have to go to HP's site.
HP Support & Drivers | United States
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Ojeg
Pls help
Thanks for the response; but I already downloaded the drivers both from ms catalog (didn't work); from HP too and still didn't work.
Funny enough the system shows signs of producing sound (drivers successfully installed, volume control sliding up and down, and even audio meter reading whenever I'm playing any file.) And yet, NO SOUND COMING OUT, neither from the speaker nor thru earpiece.
I'm pretty sure my speaker/ear-phone jacks are working fine: they were working in win 7 right up to the time I switched to win 8.
    HP
    INTEL
Kebero
HP is rapidly updating their site with Windows 8 drivers. Last night, I was able to pull down quite a few for my ProBook 4430s. With regards to IDT specifically, the Windows 7 driver works just fine - I was using that until HP updated their library.
    Windows Server 2012 Standard w/Hyper-V
    HP ProBook 4430s
    Intel Core i3-2310M
    16GB DDR3
    80GB Intel 320 SSD
    500GB Samsung Momentus
Hopachi
Pls help
Did you found something specific following post 2?
You need to install manually from device manager then.
Something was available and it worked directly!
Try the hp site as Kebero said, maybe something new is released or try Win7 drivers. That's all.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Ojeg
You mean this: "Find your hardware id string for it in device manager then put it in this website. Use the one with unique subsys string, of the 4. Leave out the revision part. Usually 2nd string down from top.
The larger drivers with the same date as smaller are x64. Smaller are x86."?
Value: HDAUDIO\FUNC_01&VEN_111D&DEV_7666&SUBSYS_103C1526&REV_1001
    HP
    INTEL
Ojeg
No new updates for hp 620; still the same old drivers for win 7. Installed but no sound.
    HP
    INTEL
Hopachi
Yes
You have to search for: SUBSYS_103C1526
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Ojeg
searched for it in ms catalog and got this response: "
We did not find any results for "SUBSYS_103C1526"
Sorry pls, I'm such a newbie in this area.
Thanks for all your assistance.
    HP
    INTEL
Hopachi
You did well. That means no specific drivers were found.
What pc do you have? x64 or x86? I'll have a look on HP-site.
Is that a notebook?
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Hopachi
Thanks,
HP 620 notebook (energy star).
x64
You'll HAVE to use the Win7 driver:
HP 620 Notebook PC*-* Download drivers and software - HP Business Support Center
version: 6.10.6300.0
Then open and extract the contents of the exe you downloaded with 7-Zip. Manually install from Device Manager.
This is in case the installer fails or is incompatible (problems) with Win8.
This is what you need:
Extract all that stuff to a folder, let's say on the desktop and go to Device Manager and do a "update driver" in the sound section:
Browse to this folder and install driver.
Even on Win8, it should detect and use a Vista or Win7 driver pretty well.
Good Luck
Nothing more to add here.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
Ojeg
Didn't work either; I guess hardware issues.
No sound, videos playing in slow-motion.
I've simply gone back to win7 --- everything is working fine
Thanks for your attention.
    HP
    INTEL
Hopachi
Too bad it didn't worked.:( Some pc models are luckier than others I guess.
If MS and HP didn't provided any newer drivers, then yes, use Win7.
Regards
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
alexd77
Try this. The only difference from the method, described there, is that GlobalSettings could be under the one of 000x keys. I had 0005. After set of EnableDynamicDevices to 0 I've got two High Defintion Audio Devices (headphones and built-in speakers). But sound works now properly without disappearing...
P.s: I mentioned standard Windows 8 drivers for IDT sound, not Windows 7.
