Solved i think i was hit? PC went nuts. need help
commander
it was nuts. the PC was going through everything in the thing. and every song, photo, forum, everything.
what could cause that and is there anything I can do to check the software looking for what ever?
    dell i660s-5390bk
    1tb
    8gb
    intel
    msn.com
    norton
Scrap Norton and get a more better Security plan if You're going to keep going on Sites like fetlife.com :confused:
Time to Kill some Malware or make a fresh install
    ME
it was like reading what was on my hard drive. I even turned it off for about 3=5 minutes and turned it back on.
and it's as if I never did anything, cause to it. I just turned it off again and left it off for hours. but I have ben getting
these popping up from time to time even stopping the PC till I clicked the X and got it off the screen
    dell i660s-5390bk
    1tb
    8gb
    intel
    msn.com
    norton
Try to install Windows Malware Remove Tool and scan the whole computer.
    Windows 10
    Acer
    Intel I7
    DDR4 16 GB
    GTX 1050 TI
    Avast
