Solved I Really Need Help
Harrier
Central Coast of California
In Firefox...
I use an Internet Speed Test site (testmy.net). I prefer it against others. For some reason something got screwed up and instead of getting the visual site that I would normally get, I just get a white page with blue text links all down the left hand side of the page.
None of those blue links will get me to what I normally see.
I have tried deleting my cookies for that particular site... no change
I have tried deleting cookies and cache in FF... no change
I get the site OK with IE, but I prefer FF.
Help appreciated.
H
Try this go toTools>options>addons>install new theme
on the website. I clicked Tools>Options..... but I don't have a (addons)
My wife looked on her PC a she don's have that either.
Sorry for this, but I'm sick and very confused....
HELP
Sorry, did not use Firefox for a long time anymore and tried to remember the settings from my memory.
But this is what i mend
Switch to the default theme
If you are using a theme other than the default Firefox theme:
1. Click the menu button New Fx Menu and choose Add-ons. The Add-ons Manager tab will open.
2.In the Add-ons Manager tab, select the Appearance panel.
3. Select the default theme, then click the Enable button, to make Firefox switch to that theme.
4. Click Restart Firefox if necessary.
After you restart Firefox, test for your problem. If it no longer occurs, the theme you were using was causing it.
Try using /installing a new/other theme in that case.
The problem is probably that the current theme is somehow corrupted.
Then it could be that this website uses Flash and i believe now Firefox has disabled Flash by default.
Probably you have to enable Flash or use a addon to see the complete webpage again.
