I need help- Dell Venue 8 Pro 5830 32GB
ltough5830
Hi all, I have a Dell Venue 8 Pro tablet that I upgraded to Windows 10. It somehow deleted the recovery partition. Windows 10 is quite bad on it and I need 8.1 back. Basically what I am looking for is an original recovery image of the Dell Venue 8 Pro 5830 32gb Windows 8.1 32-bit. The Dell OEM image. If anyone could help it would be a massive help.
Cheers,
Lewis
I can't help you with the recovery image but will say that the tablet should be able to run 10 at least as well as it ran 8.1. If you can't get the recovery image you might try doing a clean install of Windows 10.
