Solved I installed fonts, now system fonts bad.
jblo
Short story, I installed a boatload of fonts and chose not to replace any duplicate fonts. They installed ok and I was able to use them.
Then I restarted and they system fonts have all changed. Many use symbols instead of letters. This makes some functions impossible. It even effects most installed apps in some way or another.
I've tried using the "reset defaults", "restore a point" and a bunch of other suggestions from this site and others. I'm sure someone out there knows the fix. There are some suggestions to select "box color" them choose "list items-font". I've been unable to find that function on my system (8.1).
I've attached a screenshot that may point someone to a solution.
Thanks for any help.
    windows 8.1
hydranix
Either download or create this .reg file. Then merge it with your registry and logout and login to your user profile. (or reboot the computer)
Download
Contents:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Control Panel\Desktop\WindowMetrics]
"BorderWidth"="-15"
"CaptionFont"=hex:f4,ff,ff,ff,00,00,00,00,00,00,00,00,00,00,00,00,90,01,00,00,\
  00,00,00,01,00,00,05,00,53,00,65,00,67,00,6f,00,65,00,20,00,55,00,49,00,00,\
  00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,\
"CaptionHeight"="-330"
"CaptionWidth"="-330"
"IconFont"=hex:f4,ff,ff,ff,00,00,00,00,00,00,00,00,00,00,00,00,90,01,00,00,00,\
  00,00,01,00,00,05,00,53,00,65,00,67,00,6f,00,65,00,20,00,55,00,49,00,00,00,\
"IconTitleWrap"="1"
"MenuFont"=hex:f4,ff,ff,ff,00,00,00,00,00,00,00,00,00,00,00,00,90,01,00,00,00,\
"MenuHeight"="-285"
"MenuWidth"="-285"
"MessageFont"=hex:f4,ff,ff,ff,00,00,00,00,00,00,00,00,00,00,00,00,90,01,00,00,\
"ScrollHeight"="-255"
"ScrollWidth"="-255"
"Shell Icon Size"="32"
"SmCaptionFont"=hex:f4,ff,ff,ff,00,00,00,00,00,00,00,00,00,00,00,00,90,01,00,\
  00,00,00,00,01,00,00,05,00,53,00,65,00,67,00,6f,00,65,00,20,00,55,00,49,00,\
"SmCaptionHeight"="-330"
"SmCaptionWidth"="-330"
"StatusFont"=hex:f4,ff,ff,ff,00,00,00,00,00,00,00,00,00,00,00,00,90,01,00,00,\
"PaddedBorderWidth"="-60"
"AppliedDPI"=dword:00000060
"IconSpacing"="-1130"
"IconVerticalSpacing"="-1130"
"MinAnimate"="0"
    Kernel 4.x
    i5 3570K
    P8Z77-V LK
    G.skill Ripjaw Z 2133MHz 9-11-10-28
    GTX770 4GB Dual BIOS
    Audigy 4 Pro
    32" SAMSUNG HDTV
    1920x1080 progressive
    10TB total
    3 RAID arrays
    3 single disks
    Corsair HX750
    Corsair R400
    Corsair H100
    Logitech G510
    Logitech G5
    ~900mbps (~115MB/s) down, ~10mbps(~1.5MB/s) up
    Firefox & Chromium
    Common Sense
lifetec
    windows 8.1
    self build
    Intel(R) Core(TM) i5 CPU 750 @ 2.67GHz
    Asrock P55 Pro
    DDR3 Team--Elite-1333 8 gb
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    OCZ Stealth 600 watt
    Antec 300
    Speedlink Ledos and Nexus
jblo
Lifetec,
The link worked. For anyone reading this with the same problem...
The reset alone did not work. I was able to download the default windows 8 fonts. Some sites say you can drag and drop them to the font folder. That didn't work for me. You have to right click the font and select install. With almost 90 fonts it takes awhile. I found you can do 10 to 15 at a time.
As I installed them, I could see the screens fixing themselves.
I believe I caused this problem by installing too many fonts.
Thanks much for the help.
    windows 8.1
lifetec
Great, if the problem stays away could you set this thread as solved.
So that other user with similiar problems also could benefit from it.
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
jblo
Temporarily fixed, but returns.
lifetec,
Sounds like you know your stuff. Indeed, when I reboot, all the fonts go wacky again. I can reinstall them for a temporary fix, but they return to bad on a restart.
It sounds like you suspected this would happen when you said "if the problem stays away".
Any idea how to MAKE it stay away?
Thanks, again.
    windows 8.1
lifetec
    windows 8.1
    self build
    Asrock P55 Pro
    Sapphire R9 280x
    Realtek Alc 855
    Acer V233H
    1920 x 1020
    Samsung evo 850 SSd
    Seagate ST 320 gb
    Samsung HD 750 gb
    Seagate ST 3000gb
    Antec 300
