I am facing a crackling audio issue since installation of Win 8 CP
lovesingh
Hi, I am facing a crackling audio issue since installation of Win 8 CP. I have a Creative 5.1 VX Card and have updated also latest Win 7 driver as available from Creative 's Website. I also disabled on-board audio from BIOS. but still there is no luck with crackling of audio. Creative SoundBlaster control works but any audio that I play runs with some lag. I tried different players including VLC ..Please help Guys.
    Windows 8 consumer preview
    Core 2 Duo
    Gigabyte G41
    DDR3 4GB
    MSI ATI Radeon HD 5770
kbronski
Try to see if you can find a Win 8 driver. :)
    Windows 7 Professional x64
    Me? Model number... seven? two?
    Intel Core i7-5820k
    ASUS X99-A
    16GB Kingston HyperX Fury DDR4-2400 (4x4GB)
    EVGA Geforce GTX 970 SC
    Samsung 850 EVO 250GB x2; Seagate Barracuda 3.5" 7200RPM 2TB; Toshiba 2.5" 750GB 5400RPM
    Corsair RM750
    Fractal Design Define R5
    Noctua NH-D15
    Yup, it's a computer!
chev65
Closed
Try installing the driver in compatibility mode. Right click the driver, you will see it there. Run the test modes, Windows 7 mode should work best.
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
Drybonz
I have the same issue with my Creative Audigy 4. The Windows 7 drivers from Creative work, but they are a bit crackly occasionally. They are better than the default Windows drivers for my card, but still some crackly audio. I am skeptical that installing in compatibility mode will change this, and I would bet we have to wait for new drivers, if they even make them.
    Windows 8 Consumer Preview
lovesingh
I did tried re-installing the driver in compatibility mood but to no avail. Can it because of some process issue ( any background process/service interfering)?
    Core 2 Duo
    Gigabyte G41
    DDR3 4GB
GMan
Banned
If you guys are interested in doing yourselves a favor, Google for Daniel K. drivers and install the latest version that he has to offer. Use the Device Manager if necessary. He has a long history of fixing and improving Creative drivers. When 7 first hit beta, his drivers were the go to and worked very well, as opposed to Creative's own drivers.
    P4 3.4 GHz HT
    MSI-7211
    OCZ 2 GB DDR @ 400 MHz
    HIS AGP HD 3850 Turbo Ice-Q
    Acer x223w
    1680x1050
    300W generic
    Cybertron
    Logitech M510
Hopachi
Polyhedric Stellation
Hello
If newer drivers still don't fix the distorted sound, then I recommend a update (and replacement with newer driver) for your IDE/SATA controllers. It worked once for my crackled sound on Acer motherboard.
A manual update with official zip's from Intel's site is recommended. Search in your device managment for something similar:
Drivers are usually included in the Intel Chipset package. Just make sure you download the one suited for your motherboard.
After this, a reboot is necessary.
Good luck
Hopachi
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
