Solved HP Laptop charger sometime work and sometime dont work
makhan10
i have HP Laptop, its charger is giving me problems for last couple of days
sometimes it works and sometime it dont work
there is a little light white bulb near the charger, which is turned on whenever i insert the charger whether it works or not
    win 8.1
    HP Pavilion
    Intel 1.7 GHz i3 Core
    8GB
    500 GB
    8 Mbps
strollin
Old Guys Rule!
This might be due to an intermittent physical connection. It could be that the plug isn't making good contact within the socket, or the socket could have broken off the board internally or one of the wires within the cord has broken internally. If you can wiggle the plug in the socket or wiggle the wires and the light goes off and on, then it's usually one of the above problems. If the light stays off regardless, the problem could be in the charger or within the laptop itself. In that case, trying another suitable charger will narrow down the issue.
    W10 Pro (desktop), W10 (laptop), W10 Pro (tablet)
    Home built i7-8700K, Hp Envy x360 EVO Laptop, MS Surface Pro 7
    3.7Ghz Core i7-8700K, 11th Gen Core i7-1165G7 4.7Ghz, 10th Gen Core™ i5-1035G4 1.1Ghz
    ASUS TUF Z370-Pro Gaming, HP, MS
    16G, 8G, 8G
    AMD Radeon RX580, Intel Iris X Graphics, Intel Iris Plus Graphics G4
    ATI High Definition Audio (Built-in to mobo)
    Dual Samsung U32J59 32 inch monitors, 13.3" display, 12.3" display
    3840x2160 (Desktop), 1920x1080 (laptop), 2736x1824 Pro 7
    500GB ssd boot drive with 2 & 10TB Data (Desktop), 512GB ssd (laptop), 128GB SSD (tablet)
    Corsair CX 750M
    Antec 100
    Coolermaster CM 212+
    IBM Model M - used continuously since 1986
    Microsoft IntelliMouse
    665Mbps/15Mbps down/up
    FireFox, MS Edge
    Defender on all
    Retired in 2015 after working in the tech industry for 41 years. First 10 years as a Technician, the rest as a programmer/software engineer. After 1 year of retirement, I was bored so went back to work as a Robotic Process Automation Consultant. Retired for 3rd (and final) time in 2019.
EdTittel
Another sure clue that electrical problems exist is temperature: if the brick is cool, or very hot, it's probably not working properly. If it's room temp (or feels cool) that usually means it's not getting any juice. If it's very warm or hot to the touch, that is often a sign of electrical problems, too.
--Ed--
    White box
    i7 2600K
    GA Z77X-UD3H
    32 GB F3-10666
    Nvidia GTX-750 Ti
    Real-Tek HD Audio (mobo)
    2 x Dell 2707 WFP
    1980 x 1020
    OCZ Vertex 4 256 GB
    2x Jmicron RaidO 2xEVO256 GB
    2xToshiba 3GB drives
    Other drives as needed
    SeaSonic 650W 80-Plus Gold
    Antec Nine Hundred Two
    1 x 200 mm top fan, 6 x Nexus 120 mm fans
    MS Comfort Curve 4000
    Logitech M325
    100 Mbps and up (Road Runner Turbo Internet)
    IE 11, Chrome, Firefox, Safari
    NIS 2015
    Asus Blu-ray Optical Player
    Axiom Audio amp/sub/speakers (2.1)
    APC 1500W UPS
