HP G62 Intel Graphics Card Problem
amabahhar
Hi All
I Have An HP G62 With Amd And Intel Graphics Card
I've Installed Windows 8 Then I Had A Problem :cry:
Only Amd Card Is Working But Intel Isnt And I Cant Install The Driver "Minimum Requirements"
ANY HELP PLEAASE !
Its compatible, they didnt support windows 8 yet !
intel must be the one who's working because its the default gpu and amd is secondary but now amd is the default so my monitor isnt working :cry:
What's compatible? You offer very few details in your opening statement and even less in your response. Now, you think its the other graphics card that is not working? You would have been better served if you first explained where you got the driver from, what version it was, and a bit more detail about your graphics cards so one would not have to go look up everything for you. Anway, I wish you the best of luck in getting your problem resolved so hang in there and someone will be along to help you shortly.
