Solved How to Upgrade from 8.1 Retail to 8.1 OEM?
FritzCT
Reverse Upgrade from OEM 8.1 to Retail 8.1
So I have a copy of win 8.1 Pro 64 bit OEM. I wanted to add Media Centre to this so after following lots of links (from Add features) I managed to download and install what I thought was the stand alone Media Centre. It turns out it was not a stand alone but in fact "upgraded" my OS to Win 8.1 Pro with Media Centre (a retail version). Now I don't have a licence for retail, only OEM and my PC now has this new OS (Build 9600) on it that I can't activate.
I've thought of restoring but I no longer have any restore points back to when the OEM version was there.
What I'm hoping I can do is use my OEM cd to "upgrade" back but I don't have the faintest idea if or how I can do that.
If all else fails I do have a very old image of my PC (as in day one after the original build back in May of this year) but I'm not even very sure how to use that.
Any help would be very much appreciated.
Fritz
EDIT: Just to clarify. I used a generic code to download what I thought was a stand alone Media Centre app but it wasn't. It was a generic code for Win 8.1 Pro with Media Centre (Retail) which I now cannot activate so I want to go back to my OEM copy
    Windows 8.1 Pro 64 Bit
    I7-2600K
    ROG Maximums V Formula
    8 Gb Hyper X
    GTX 770 2 Gb
scandal1981
you have to upgrade to retail professional, then to wmc
    Intel Core i5-4460, 3400 MHz
    Gigabyte GA-H81M-H
    2x4GB DDR3 1600Mhz Kingston
    Nvidia Geforce GTX 750
    Onboard Sound
    Samsung 23" 1080p HDMI
    WDC WD5000AAKX-00ERMA0 (500 GB)
    Thermaltake 750w toughpower
FritzCT
Hi, thanks for the reply. I think my title might be a little misleading. I don't want to have to buy a new licence just to get Media Centre. what I'm trying to do is somehow roll back to the OEM version without having to resort to a clean install (or a restore from the image I have).
When this "upgrade" happened it wasn't like installing a new OS. None of my programs etc were affected, no re-installation of any thing. Is was like a windows update really and I'm hoping it can be reversed in the same way.
Fritz
    I7-2600K
    8 Gb Hyper X
    GTX 770 2 Gb
FritzCT
No it doesn't. I know I'm in retail because I spoke to MS support and they told me what had happened. They looked for a restore point, couldn't find one (I had already looked) and said simplest way back is to re-install. I'm just hoping there's another way back without me having to do a clean install
    I7-2600K
    8 Gb Hyper X
    GTX 770 2 Gb
alphanumeric
slightly off center
Gold Member
To add Media Center though Add Features you have to be running 8.x Pro. If you were running 8.x Core you cannot add Media Center. You can go from Core to Pro though Add Features by entering a valid Pro product code. No install media is needed. Once your upgraded to Pro you go to Add Features and enter your valid Media Center key. Again, no install media is needed.
EDIT: Removed some stuff that was already answered, just didn't see it.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
alphanumeric
slightly off center
Gold Member
There is no easy way to go back once you upgrade to Pro or add Media Center. Old restore points are deleted, likely because if you used one of them you would mess up your system.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
alphanumeric
slightly off center
Gold Member
This generic code you entered? Where did you enter it, in add features? If you open the System page does it show Windows 8.1 Pro or Windows 8.1 Pro with Media Center?
    Asus
    Thermaltake TR 620
    Stock heatsink fan
FritzCT
Ok so I was using 8.1 Pro (OEM). If I remember correctly there was a link under Windows Edition in System (it doesn't seem to be there now though) that I followed. I then followed on screen prompts that eventually took me to an upgrade page. That's where I used the code. The system re-booted and it now says Windows 8.1 Pro with Media Centre, which MS support have told me is a retail version for which I would need to buy another key to activate. All links followed were direct from windows and then from MS page to MS page, no external links.
I'm not going to buy a new key just so I can have Media Centre so I'd like to go back to my OEM version, which I can activate.
Fritz
    I7-2600K
    8 Gb Hyper X
    GTX 770 2 Gb
How about this---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
SaggyMaggyPoo
I'm not a techie, but having lived through some refreshes and restores recently, I thought the following might be of interest:
If it's OEM maybe you have a Recovery partition that you can restore back to. Or maybe you could Refresh (which I think uses that same Recovery partition if it exists, otherwise may work with your cd).
Problem is that whichever of these options you use, you will lose all programs you have installed since you first started, but with refresh at least you keep your files. Plus if your OEM was W8 it will take you back to W8 again.
If you have a system image that you made after you set up Windows as you wanted it that could avoid having to reinstall programs but you might still have to go through all the updates to W8.1.
Or you could have a look at this thread:
http://www.eightforums.com/windows-8-news/56837-official-microsoft-iso-media-creation-tool.html
which will allow you to download a copy of W8.1 complete with updates to use as a fresh install. But again you wouldn't have all your additional programs and files.
Think you will probably have to choose which of these is the least painful and go for it :(.
    Win8.1 64bit, Windows 10 TP on VMWare Player
    Dell Inspiron 15 3521
    1.80 gigahertz Intel Core i5-3337U
    Dell Inc. 0010T1 A00
    8gb
    Intel HD Graphics 4000
    Realtek HD Audio & Intel Display Audio
    TOSHIBA MQ01ABD050 [Hard drive] (500.11 GB)
    Additional fan
    Kensington Trackball
    IE
    Emsisoft Internet Security, Malwarebytes free & antiexploit
alphanumeric
slightly off center
Gold Member
Fritz
Once you add Media Center the Add Features link goes away. There are no more features to add. Also, once you add Media Center, Windows activates with the Media Center key. That's your issue now, your Media Center key is blocked from activation. My guess is you used a key that was floating around for use with the preview builds. That key is now blacklisted by Microsoft. Do you have another Media Center key? If not your going to have to reinstall 8.1 Pro to get back to a legally activated system. You can't just uninstall Media Center either. You can turn it off in Windows features but that won't fix you activation issue.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
FritzCT
Thanks for the help guys, feeling like such a dinlo right now.
Fritz
I think you have summarised my problem perfectly (the term preview absolutely rings a bell) and it sounds like the clean install/ restore from image might be my only option.
@saggymaggy, yes I'm, kind of hoping that there's still an image/ restore that I can access another way but it seems not.
Lesson learnt, don't play with things you don't really understand!!
If I go for the image restore what should I be saving/copyig before I do so?
Fritz
    I7-2600K
    8 Gb Hyper X
    GTX 770 2 Gb
SaggyMaggyPoo
Fritz
I would suggest you copy all your libraries (docs, videos, pictures etc.) onto an external drive. If you do a refresh you will still have these but no harm in doing it just in case. And you won't have them if you do a restore, factory restore or fresh install.
Also export all your browser favourites. And try to get either a .exe for all the 3rd party programs you have installed, or know where to go to get these back.
Basically anything that wasn't there when you first got the machine may be lost depending on the method used. I tend to go for overkill and save things even if I may not lose them.
I did a refresh (well 2 actually), which sort of kept my Windows Store apps. They were listed in my Store account but I had to reinstall them. And I lost my history on them (I was playing solitaire daily challenges and lost everything I had done during the month).
If your system image is very old, you might not gain a lot from using that unless it does have the 3rd party programs you want to keep.
If you choose to refresh or recover, remember this will take you back to W8 if that was what you started with. There will then be well over 100 updates to install before you can move up to W8.1, plus a stack more afterwards. You can get challenges from trying to install all the updates in one go and it can take a few attempts (and several hours) to get through the process.
If I have to do this again, I will definitely be looking at the clean install from the link I posted before. It should remove a lot of the pain of getting back to where you are now.
On the positive side: it could be a good opportunity to do a clean-up of programs that seemed like a good idea :).
And there is a lot of helpful advice on the forum, including lots of tutorials that will give you a step by step guide to refreshing, restoring etc. I'm not very technical but the information on this forum has helped me work through a whole range of issues.
Good luck whatever you decide to do.
    8gb
    Additional fan
    IE
alphanumeric
slightly off center
Gold Member
I think this will work for Windows 8 also, I just don't know what you would enter, UNAWAVE - Downgrade Ultimate to Home Premium or Professional
I'm pretty sure at least one forum member has tried it, but it will be a really old thread and hard to find. You need somebody with Core (I think) to look up what they have listed in their registry. All my PC's are running 8.1 Pro with MC so I can't help you with that. Just backup the registry key before you try editing it, if you decide to try it. What do you have for install media? You may have to download 8.1 Pro from here, Create installation media for Windows 8.1 - Windows Help
    Asus
    Thermaltake TR 620
    Stock heatsink fan
adamf
Banned
This tutorial uses the same method to remove WMC from 8.1 Pro so should let you revert to non-pro also - http://www.eightforums.com/tutorials/16077-media-center-remove-go-back-windows-8-pro.html
:ditto: - I don't have non-pro either unfortunately.
    Windows 10 Pro Prieview x64
    MacBook Pro Core2Duo
    T7600
    ATI Radeon X1600
    Internal
    1440 x 800
    40GB
    Apple
    Apple
    Varies
    Various
    Defender
Wenda
That's why I love system images, Alpha... always dead easy to go back (assuming the image you restore is a good one - I have struck a bad one occasionally).
Wenda.
    Windows 8.1 'Ultimate' RTM 64 bit (Pro/WMC).
    Acer AS8951G 'Desktop Replacement'.
    i7-2670QM@2.2/3.1Ghz.
    Acer
    8GB@1366Mhz.
    GeForce GT555M 2GB DDR3
    Realtek HD w/Dolby 5.1 surround.
    Built-in. Non-touch.
    18/4" 1920x1080 full-HD.
    Toshiba 750GBx2 internal. 1x2TB, 2x640GB, 1x500GB external.
    Stock.
    Laptop.
    Stock.
    Full 101-key
    USB cordless.
    IE11, Firefox, Tor.
    Windows Defender, MalwareBytes Pro.
    BD-ROM drive.
alphanumeric
slightly off center
Gold Member
I didn't think there was a tutorial on that or I would have looked, my bad. I do believe the OP has an 8.1 Pro key so that should work for him. I just wasn't sure if you had to change it to Pro or Core in the registry. Now we'll just wait and see what the OP actually does or did.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
FritzCT
Ok so do I understand correctly that the 8forums 16077 link you have provided is to remove MC from win 8 Pro with MC and revert back to win 8 Pro. Because this sound like what I need to do albeit with 8.1 not 8. I don't own 8 and never have the original install on this PC was Win 8.1 Pro 64 bit OEM.
If so I assume I can just change the Product Name to Windows 8.1 Pro instead of Windows 8 Pro as in the tutorial?
I have the original install disk still so there's no need for me to create the install media.
Assuming I do this and it all goes wrong will I still be able to use my May restore image?
I guess you can guess what I'm thinking. Try to go back using the link posted and if that fails use my image.
Also many thanks for your help so far, it is very much appreciated.
fritz
EDIT: I have 83 Gb of 223 Gb available on my C drive. I think that's plenty but is that enough?
EDIT 2: The original install was Windows 8.1 Pro OEM so if anyone has that please can they tell me what their registry says
    I7-2600K
    8 Gb Hyper X
    GTX 770 2 Gb
