Solved How to turn Recycle Bin confirmation *off*
Freshdaemon
I seem to have the reverse problem of everyone else: my Windows 8 insists on confirming every delete request and I can't disable it. The boxes for confirm delete in recycle bin properties are definitely unchecked, and yet every time I try to delete something (from anywhere, including local drives) it asks for confirmation. I've tried checking and re-unchecking the delete confirmation box, and I've tried reverse psychology (!?) and checking the delete confirmation box - no change at all.
[Solved] - network drives don't behave the same way and will ask for confirmation before deletion every time. Make sure it's a local drive and not a networked drive.
    Custom
    Intel i5 2500K
    Asus P8Z68-V Pro
    4x8GB Kingston KHX1600C10D3B1K2
    Zotac Geforce GTX 670
    FiiO Olympus USB DAC/AMP
    Acer SB280HK, 2x Korean 1440p IPS displays
    3840x2160, 2560x1440 (2)
    Samsung 830 Pro 256GB
    WD Black 1TB
    WD Green 2TB
    Silverstone Strider 1000 Plus
    NZXT Switch 810
    Corsair H110
    Ducky Shine 3
    Logitech G500
    50Mbps/12Mbps
    Chrome
AddRAM
R.I.P. Gary
Do you also have it set to delete immediately ?
On every drive ?
    Windows 7 Pro x64 Windows 10 Pro x64 Build 9926
    Gateway GT5404
    Intel Core 2 Duo E6700 @ 2.66 GHz
    Intel D945GCL
    4GB PC2 6400 @ 800 MHz CL 6-6-6-18
    MSI GTX660 TF3 2GB
    Realtek HD
    Gateway FPD1975W
    1440 x 900
    Samsung 850 EVO 120GB SSD / WD 500GB
    Corsair HX750
    OEM
    OEM
    Gateway KB-0401
    Gateway MOAKUO
    Verizon Quantum Gateway 60 / 60
    Chrome / IE11
    MSE / Defender / MBAM
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
md2lgyk
I have the same issue. No matter what I try, the confirmation dialog can't be stopped. "Delete immediately" is not checked, nor has it ever been.
    Win 8
Freshdaemon
Nevermind, I'm an idiot. I hadn't realized that it was a mapped network drive which was asking for confirmation, which makes sense because that's gone forever. Local drives are actually behaving as expected.
md2lgyk, is that the same pattern you're having or something else? If your local drive(s) is misbehaving I'll leave this unsolved for you.
    Custom
    Intel i5 2500K
    Asus P8Z68-V Pro
    WD Black 1TB
    WD Green 2TB
    NZXT Switch 810
    Corsair H110
    Ducky Shine 3
    Logitech G500
    50Mbps/12Mbps
    Chrome
