How to set performance options for "regular" users?
jdm43
... and have them stick?
Quick question - I am trying to disable "Animate controls and elements inside windows" as well as a couple of other options in System Properties > Advanced > Performance > Custom for a "regular" Local Account on Windows 8. No matter what I've tried (and that's pretty much been limited to turning UAC off temporarily) I cannot get my choices to last past the current session. The moment I log off, they all revert to whatever Windows 8 thinks should be the default. This (turning UAC off temporarily) worked on Windows 7, but I am unable to get it to work on 8. Any words of wisdom?
Many thanks in advance for your help!
JM
    Lenovo
    Mobile QuadCore Intel Core i7-3632QM, 2400 MHz (24 x 100)
    Lenovo
    8048 MB (DDR3-1600 DDR3 SDRAM)
    Intel(R) HD Graphics 4000 (2112 MB)
