How to set Lock Screen image from right click menu
Haikgh
Hello.
How can I add a right click menu to an image file in order to be able to set it as a Lock Screen background.
P.s. Reg. file I guess?
Thanks
    Windows 8 Pro-64 bit
    Intel Core i5 M430
    4 Gb
    Mobility Radeon HD 5650 1024MB
    1366x768
    Toshiba 500Gb
    Eset Smart Security 6
Der Snoober
Hi there Haikgh,
no, it is not possible to add a feature to the rightclick menu to set a picture directly as lock screen background.
There is however a workaround! You can use the rightclick menu to set a picture as your dekstop background. And using a program like decor8 (Decor8 - Personalize the Windows® 8 Start screen with Decor8™!), you can change a setting so that the lockscreen is always the same as your desktop background.
Goodluck with it!
Greetz,
Rover
    Windows 8.1 Pro x64 Media Center Edition
    Custom Made
    Intel Core i5 750
    6 GB
    AMD HD 7750
    Iiyama ProLite B2481HS-B1
    1x 120 GB SSD Samsung 830;
    1x 1.5 TB HDD Seagate;
    1x 2 TB HDD Western Digital;
    1x 3 TB HDD Seagate
    1x 80 GB SSD Vertex 2
    Corsair CX 600
    Corsair Carbide 300R with Side Window
    Intel RTS2011 LC
    DasKeyboard (blue switches)
    Wacom Baboo Tablet Pen & Touch
    50 Mbit FullDuplex Fiberglass
    IE11
    I also own the following Microsoft devices:
    * Surface Pro 2 128 GB
    * Windows Phone HTC 8X
Haikgh
Appreciate your response very much Der Snoober.
Thanks for the tip, too. I wouldn't wanna have both pictures the same, though :)
Thanks
Een mooie dag verder.
    Intel Core i5 M430
    4 Gb
    1366x768
    Toshiba 500Gb
Haikgh
Thank you man. I'll try it out.
I am still hoping to get some kind of .reg file which would add a line in a right click menu of the image file to set a the picture to lockscreen directly :)
    Intel Core i5 M430
    4 Gb
    1366x768
    Toshiba 500Gb
Hopachi
Polyhedric Stellation
Not sure if anyone made that yet. But should be possible somehow I just don't know how.
Have a look at the Bing App: it can add the Bing background image to the Lock Screen.
Maybe Internet Explorer can do that as well... the Metro one? Don't know.
    Windows 10 x64
    HP Envy DV6 7250
    Intel i7-3630QM
    16GB
    IDT HD Audio
    multiple resolutions
    120W adapter
    small
    laptop cooling pad
    SteelSeries Sensei
    slow and steady
    That's basically it.
