Solved How to save the oldest existing system restore point?
djamiljo93
Hi, guys, this is my first post here, I just discoverer this forum :D
I bought a new 240gb ssd lately and i installed windows 8.1 on it and I wanted this time to create a system image to eventually restore my windows at that point. But I forgot to do it and installed a lot of programs that I would not like to have installed if I had to restore windows. The thing is that when I go to system restore i can see there is 2 restore points.
So I would like to know if there is a way to create a system image from an existing(oldest) restore point without actually having to restore to that point.
I made researches on google but I only found ways to delete (all or just keeping the last) or change the space allocated to system restore points.
I also found this
http://www.eightforums.com/tutorials/8956-system-image-create-windows-8-a.html
Can I do the same like in this post and change a folder name to copy-1?
the thing is that I could not even find something about the location of system restore points in the actual drive :huh: ...
    windows 8.1 pro 64bits
    I7-2600k
    p8p67 pro rev 3.1
    G.SKILL Ripjaws X Series 8GB (2 x 4GB)
    GIGABYTE SuperOc GTX 570 (1280MB)
    Asus VE248H Black 24"
    Sandisk Ultra II - 240gb
    WD Black - 1tb
    Corsair Force Gt - 60gb
    Antec High Current Gamer Series 900w
    Cooler Master HAF X Nvidia edition
    firefox, chrome
    Country Flag
    Canada
    State/Region Flag
    ca quebec
Hello djamailjo, and welcome to Eight Forums.
I'm afraid not.
When you create a system image, it will be of the current state of your system.
You'll either need to uninstall the programs, or use a restore point dated before you installed them to undo them. :(
If they are programs that you usually install and use anyways, then it would be more convenient for you to have them included in the system image to avoid having to reinstall and set them up again though.
    Name
    Shawn Brink
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
    State/Region Flag
    us oklahoma
LMiller7
Active Member
To conserve disk space a restore point contains only specific file types and portions of the registry that have changed since the previous restore point. It does not contain nearly enough information to create an image.
Restore points are stored in the "System Volume Information" folder of the protected drive. By default even an elevated Admin account does not have access to this folder and that is why it shows as empty. By default this folder is hidden and visible only if hidden files are configured to be visible. Direct access to this folder is for experts only.
    Windows 7
    Country Flag
    Canada
    State/Region Flag
    ca saskatchewan
djamiljo93
Too bad than :/ I know I could create a system image right now, restore windows to that oldest restore point, create a system image of that specific state and than restore windows using the first image but that's too much of a pain especially when I know I'm going to install windows 10 in not so long. I also asked by curiosity, I thought there might be a way maybe using some commands in cmd but anyway I'll try not to forget to do it at the right time when I'll upgrade to windows 10 :p thanks guys for your reply :)
    I7-2600k
    p8p67 pro rev 3.1
    WD Black - 1tb
    firefox, chrome
    Country Flag
    Canada
    State/Region Flag
    ca quebec
