Solved How to resize Surface 3 Pro drive by third party utility
churin
185
I could manage to resize the system partition by using a third party utility software but think there must be more efficient way to do it. Here's how I did it:
1. I let the Surface 3 Pro boot from a USB bootable drive for the third party utility.
2. Noted that I could not resize the OS drive or any drive.
3. I disabled TPM and Secure Boot Control on UEFI.
4. Surface 3 Pro did not boot and instead got to recovery mode asking for recovery info.
5. I could not find the info anywhere and I reset the Surface 3 Pro.
6. I launched the third party utility again and could resize the partition this time.
BTW: After the step 6 I enabled TPM and Boot Control, and now I can no longer resize the partition.
Any suggestions?
    W10 Pro/W8.1 Pro/ W7 Ult
    AMD FX 6300 x6
    Gigabyte GA-970A-UD3
    8GBx2 DDR3 1866 G.Skill F3-1866C9D-16GXM
    Radeon R7 360
    Asus Xonar DS
    Dell P2715Q
    3840 x 2160
    Samsung 840Pro SSD 256GB, Samsung 850 Pro 1TBx2 RAID1
    Corsair CX430M 500W
    Corsair 200R
    Zallman CNPS5X
    180Mbps/12Mbps
    Firefox & IE
    BD Writer LG WH14NS40, DVD RW Pioneer DVR-218L
KYHI
2,764
TPM = Trusted Platform Module
SecureBoot = Prevents anything from loading before the OS
Both have to be disabled - before trying to boot from 3rd party software.. So it is working as it is suppose to be..
Your system most likely has 5 partitions ( standard setup for OEM PC's) or has 4 partitions if it has a 32GB drive or less (usually a wimboot setup)
So what is it you looking for suggestions for ?
    Windows 3.1 > Windows 10
    Dell XPS 8700
    I7
    24 GB
churin
185
If both are disabled my experience as stated in my previous post indicates I have to go through the step 4 to 6. I would think this cannot be the solution. Or the recovery mode is not supposed to happen?
    AMD FX 6300 x6
    Radeon R7 360
    Asus Xonar DS
    Dell P2715Q
    3840 x 2160
    Corsair CX430M 500W
    Corsair 200R
    Zallman CNPS5X
    180Mbps/12Mbps
    Firefox & IE
broe23
Retired from the grind
Central IL
3,468
There are some Linux distro's that will work with UEFI on, You just boot up on the USB stick that holds the Live version of Linux, then resize with Gparted.
    Linux Mint 17.2
    12GB
    AMD Radeon™ HD 7310 Graphics
    Realtek HD
    LCD
    1366 x 768
    Crucial M500 240GB SSD
    Logitech M525
    45/6 - ATT U-Verse
    None needed. It is Linux.
churin
185
I am not familiar with Linux. Could anyone point me to a specific Linux distro?
    AMD FX 6300 x6
    Radeon R7 360
    Asus Xonar DS
    Dell P2715Q
    3840 x 2160
    Corsair CX430M 500W
    Corsair 200R
    Zallman CNPS5X
    180Mbps/12Mbps
    Firefox & IE
churin
185
broe23,
Do you mean encrypted drive can be accessible from Linux so that I can resize/create/delete its partition?
KYHI,
Thanks for the info but this is not a Linux distro or is it?
    AMD FX 6300 x6
    Radeon R7 360
    Asus Xonar DS
    Dell P2715Q
    3840 x 2160
    Corsair CX430M 500W
    Corsair 200R
    Zallman CNPS5X
    180Mbps/12Mbps
    Firefox & IE
broe23
Central IL
3,468
#8
If the partition or drive is encrypted, You need to turn it off, before the resizing.
    Linux Mint 17.2
    12GB
    Realtek HD
    LCD
    1366 x 768
    Logitech M525
    45/6 - ATT U-Verse
KYHI
2,764
#9
Trusted Platform Module (TPM) is an international standard for a secure cryptoprocessor, which is a dedicated microprocessor designed to secure hardware by integrating cryptographic keys into devices.
thus
    Dell XPS 8700
    I7
    24 GB
churin
185
#10
Thanks everyone for your help.
I have found out by now that my problem was that I did not know the Surface 3 Pro's hard drive was encrypted out of the box.(W8.1 automatically encrypts if the hardware supports) The encryption key did not come in the box, thus I could not enter the key when requested. BitLocker key I knew is that it is created when a storage device is encrypted. In my problem case, it came encrypted but the system is set up to allow the key to be backed up by the user. I was supposed to back up the key or turn off the encryption soon after the initial basic configuration was done.
Any comment or correct me if any part of the above is incorrect.
    AMD FX 6300 x6
    Radeon R7 360
    Asus Xonar DS
    Dell P2715Q
    3840 x 2160
    Corsair CX430M 500W
    Corsair 200R
    Zallman CNPS5X
    180Mbps/12Mbps
    Firefox & IE
