Solved How to make my primary drive GPT1 and my second drive GPT2
orlando1974
173
I have a laptop that has an SSD with Win 8.1 + programs, and an HDD for projects. They are both formatted GPT. When I launch Macrium, for some reason my SSD is now GPT 1 and the second drive is now GPT 2. This is confusing because I'm used to imaging the top line of partitions which is usually my OS. Now that the GPT numbers are reversed, I have to be careful when doing my backups.
Does anyone know how to change this assignment so that the SSD will be GPT1 again?
    Win 8 64-bit
CountMike
Belgrade , Serbia
4,664
I just give them separate names, "System" for first, boot drive, "Data 1", for next and others by names that describe what I'm using them for. That way there is no confusion when some programs or OSs reverse or mix order.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
orlando1974
173
Hmm, this doesnt truly answer my question Count Mike. They already have their own names. I'm talking about some sort of assignment that is done under the hood. In Disk Management, the primary drive was bumped to Disk 1 after I installed the second drive, which took its place as Disk 0.
Is there no way to exchange these assignments?
Update: looks like its a common issue for which there is no definite solution... Disk numbers in Disk Management matters? - Windows 7 Help Forums
    Win 8 64-bit
CountMike
Belgrade , Serbia
4,664
Maybe if you changed their places on the SATA ports in MB. It just stands to reason that HDD0 becomes GPT1 and next one GPT 2. It's also logical that BOOT/system drive be first drive /HDD0.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
orlando1974
173
I cannot change their ports... this is a laptop that came with ONE drive. I swapped it out for an SSD and installed Windows 8.1 on it. Once all that was done, I installed a second drive where the optical drive used to be, using an HDD Caddy. This is what bumped the SSD to Disk 1 from Disk 0. So it actually looks at where my optical drive used to be as Disk 0! Hmmm...
    Win 8 64-bit
CountMike
Belgrade , Serbia
4,664
Anything in BIOS that can turn things around. I know, laptop BIOSes are not exactly power houses but.....
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
orlando1974
173
Not sure where I would look.
Off topic, in going into my American Megatrends bios I did notice that Fast Boot is set to Disabled. I'm already finding the boot is incredibly fast... and this is turned off. I wonder if I should turn it on.. i dont know what it does?
    Win 8 64-bit
CountMike
Belgrade , Serbia
4,664
#8
Goes faster thru BIOS, no relation to OS. Starts Booting faster before windows starts to boot. With an SSD really not necessary.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
orlando1974
173
#9
OK thanks.... well original question not solved still, so I'll leave the thread open for a bit. Seems to me there's no solution... seems to have happened to lots of people when they install an SSD alongside other drives. Weird though because I had specifically installed OS prior to connecting second HDD.
    Win 8 64-bit
CountMike
Belgrade , Serbia
4,664
#10
You did that part right, why is GPT switching and if on MBR it does not happen ? If you are using GPT because of UEFI Bios, you don't need second HDD to be too, MBR should work on it.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
orlando1974
173
#11
Yeah, i guess its probable that if second HDD was MBR, I would not have this problem...
I'm not interested in starting all over though so I guess I'll have to live with it.
    Win 8 64-bit
CountMike
Belgrade , Serbia
4,664
#12
Wise decision, I'm sure you'll get used to that arrangement in no time. Look at it from the bright side, with GPT on second drive you'd be able to install another OS with UEFI , Win9 is coming soon.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Clintlgm
Active Member
Lacombe, Louisiana
894
#13
Actualy you can convert a Logical drive to from GPT to MBR UEFI will recognize it. It is only primary drive with an OS on them that can not be converted.
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
Clintlgm
Active Member
Lacombe, Louisiana
894
#15
And how would I do that? Within Windows DIsk Management? Would this lead to a loss of data on the drive?
On further research I guess you can change a MBR to GPT but not the other way around So I spoke wrong.
    Windows 8.1 Pro MC
    Z97 Pro
    VIA 6.0.10.1600
    30 down 3 up
    Explorer 11
rowlands111
53
#16
I know exactly what you mean orlando1974.
I recently installed an SSD to my machine, and in Macrium, the top line is of course ''GPT 1'' but it pertains to my original HDD>which is now purely a storage drive - the annoying thing is, I was able to delete all the original partitions off it that Windows 8.1 had set, aside from some anonymous 128MB ''unformatted partition'' - it's some sort of Windows partition of course. Due to this, Macrium assumed that HDD also needed to be backed up, as it had a System partition on it.
The good news is that in their newest update which was literally only released, the software can ascertain the correct bootable disk (in our case, the SSD) and if you select the task ''Create an image of the partitions required to backup and restore Windows'' it selects GPT disk 2 which is correct again in this scenario.
I however understand that you want to have full control over how you use the software, I don't have an answer to your original question though sorry. I'm sure we'll be careful enough not to be careless when selecting the appropriate backups :)
    Acer Predator G3-605
    Intel Core i7 4770 @ 3.4GHZ
    Acer Predator
    16GB DDR3 @ 798MHz
    Nvidia GTX 770 2GB - Personally Overclocked
    N/A
    Acer Pradator full HD LED 24''
    Corsair Neutron GTX 240 GB (Boot)
    2 TB Seagate
    500W
    Acer Pradator G3-605
    All standard
    Corsair Raptor K50 RGB
    Acer Optical Mouse
    40Mbps
    Chrome
    Bitdefender Windows 8 Security
orlando1974
173
#17
Thanks for letting me know rowlands. Are you on Macrium Free version?
    Win 8 64-bit
rowlands111
53
#18
I'm actually on the Pro version myself but would assume that as long as you're running 5.3.7086 then the same should apply, as you might guess! Here is the release notes in case you're interested -
Macrium Reflect Patch Details
    Acer Predator
    16GB DDR3 @ 798MHz
    N/A
    2 TB Seagate
    500W
    All standard
    Acer Optical Mouse
    40Mbps
    Chrome
rowlands111
53
#19
I was referring in particular to the fix that says ''
  • [FONT=Verdana, Arial, Helvetica, sans-serif]'Backup Windows' will now only include the actual boot disk in a UEFI booting systems where multiple EFI system partitions exist.
    Multiple GPT disks with multiple EFI system partitions would cause incorrect selection of non-booting disks. This has been resolved.'
    Again, know it doesn't really resolve your query..[/FONT]
    Acer Predator
    16GB DDR3 @ 798MHz
    N/A
    2 TB Seagate
    500W
    All standard
    Acer Optical Mouse
    40Mbps
    Chrome
orlando1974
173
#20
Well at this point I dont really need to know why my GPT 0 got bumped to GPT 1. I know many others have reported the same so its not like its only me. What matters more is that Macrium fixed the issue so now I wont have to worry about not selecting the right GPT Disk! (hopefully the fix will work for me!).
So thanks again rowlands. Your solution was good enough to solve this thread. :)
    Win 8 64-bit
