Solved how to fix my external hard disk
ismailkhw
1
well, my external hard disk was working just fine then it started showing as "local disk E" and i couldn't open it. I searched online for a solution and did the "chkdsk" thing and it worked again. few hours later the problem game back.. this time what i did before didn't solve it. it only made the contents of the hard disk appear but i couldn't use it .. so i copied some of the small files i needed from my 300 gb of data on it. now it's back to the "local disk e" thing and i can't even use cmd while the hard is connected. is there a way to solve it or at least copy my files from it?
Edit: now i can't even use cmd or disk management or my computer when the disk is connected
    windows 8.1
topgundcp
San Jose - California
2,847
  1. Back up your personal data while you can
  2. Download CrystalDiskInfo.V6.2.0 and run to check if your HD is any good.
  3. Try to run: chkdsk X: /r /f ======> X is the external drive letter. Will take a while to complete
  4. If happens again then replace your HD.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
LMiller7
Active Member
704
You should always make a backup of important files before problems develop. 2 or more backup copies if the files are of particular importance. Trying to make a backup after problems occur may be too late. Recovery methods are always hit or miss.
    Windows 7
