Solved how to enable small icons in taskbar menu using registry tweak ?
polas
8
Hi all.
I have a simple question how to reduce the taskbar menu icons using regedit
For now they are big to me.
Of course I know how to reduce the taskbar menu icons but I want to reduce them using registry.
Is there any trick to do this?
Maybe someone you know and you can help?
here is where i want to change it to smaller icons on taskbar meniu.
And this is the way i know how to change but not do not know how to do that with registry.
Thank you in advance.
    windows
24,025
Hello Polas, and welcome to Eight Forums.
The way you are showing is how to change the size of the icons on your desktop, but not on the taskbar.
OPTION TWO or THREE in the tutorial below can show you how to change the taskbar icons to be large or small using the registry. It's the same in Windows 8.
Taskbar - Use Small or Large Icons - Windows 7 Forums
Hope this helps, :)
    3 x 27" Asus VE278Q
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
24,025
You're most welcome. :)
    3 x 27" Asus VE278Q
    Logitech MX Master
    Lumia 1520 phone
