Solved How to Disable Right Click area on Synaptics ClickPad
Gibs
16
Hello all. I just recently purchased a windows machine and I would like to disable the right click area of the trackpad. Since you can use two fingers to right click, I don't see any reason to have that area designated for that purpose. I have searched all through all of the trackpad settings, then google to find a solution with no success.
Any ideas?
    Toshiba Satellite P75-A7200
    Intel Core i7
    8GB
rvcjew
I just want to hep!
USA, CA
191
since synaptics has lots of trackpad versions can you take screen shot of your trackpad software so we can help you further please. also are you trying to disable a touch area of the trackpad or a physical button?
    WIN 7 PRO x64, WIN 8.1 PRO x64
    Custom
    Intel i7 4790K
    ASUS Maximus VI Extreme
    32GB(4x8GB) DDR3 Team Xtreem 2666 @ 2400 CL10 10-12-12-31
    2x MSI GTX 780 Twin Frozr OC 3GB
    ASUS Xonar Essence STX
    ASUS PB278Q, HP 2311xi, UN46F7100AFXZA
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    10TB RAID 0 Array (Movies, Steam)
    6TB RAID 1 Array (Backups, Documents)
    3TB EXT Drive (Secure Backups)
    Corsair AX760
    NZXT White Switch 810
    Block: XSPC Raystorm, RES/Pump: XSPC Bay res W/D5 Vario, RAD: XSPC RX360, 6xNF-F12's
    Rosewill RK-9000 with MX Blue switches Logitech G15 Rev 2 (gutted for LCD)
    Logitech G400
    Chrome
    I also own a Lenovo Y510p, and Yoga 2 Pro
Gibs
16
Ok I will do that. It is not a physical button but just the bottom-right area of the trackpad.
    Intel Core i7
    8GB
Gibs
16
I believe this displays the information you need.
    Intel Core i7
    8GB
rvcjew
I just want to hep!
USA, CA
191
yeah click settings then you will get its options. my laptop finally came back from service repair (had a bad speaker and so i sent it to them after finding out i had to remove the MB to replace it and didn't want to have to be liable and so had them do it, they sent it back with a new MB and a new speaker wtf the MB was fine lol) so i can take a pick of the actual settings if you want. EDIT: had to get something off the laptop anyways so here you go.
    Custom
    Intel i7 4790K
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    Corsair AX760
    Logitech G400
    Chrome
Gibs
16
Unfortunately that is not the same settings menu I have.
This is what it looks like.
Thank you for the images though!
    Intel Core i7
    8GB
rvcjew
I just want to hep!
USA, CA
191
Oh my old laptop has that one click tapping then the gear. No wait is not on so is not that is something in there though click the ones that are checked then the gears to change it.
    Custom
    Intel i7 4790K
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    Corsair AX760
    Logitech G400
    Chrome
Gibs
16
#8
Yes I did go through the settings on the different options but I must have missed one! Here is a shot of the dialogue boxes.
You cant just disable Corner Click Action, or that portion of the trackpad wont function. You have to turn it to primary click.
    Intel Core i7
    8GB
rvcjew
I just want to hep!
USA, CA
191
#9
oh so it solved it then? as it now only a full left click button right? unless you tap with two fingers, or are you just not going to not use tap at all? also thanks for the rep:)
    Custom
    Intel i7 4790K
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    Corsair AX760
    Logitech G400
    Chrome
Gibs
16
#10
I just plan on using the two finger tap for the right click option. The default right click area portion of the track pad is unproportionally large in my opinion, so I would constantly right click on accident when trying to left click. Removing the area completely fixed this issue completely. Thanks again.
    Intel Core i7
    8GB
rvcjew
I just want to hep!
USA, CA
191
#11
ah mines a big button and when click if i have two fingers it's a right click. I can also tap and the bottom area works as a normal left and right click button space too, it feels loose at times because of the design though.
happy to help.
    Custom
    Intel i7 4790K
    2560x1440p, 2x1080p
    256GB 840 PRO SSD
    Corsair AX760
    Logitech G400
    Chrome
simondva
Left zone turned off
happy to help.
Hi! I have the same settings at the synaptics options, but when I uncheck the "Enable secondary corner click" box it turns the lower left zone of the trackpad off... Kind of good because there are no accidental right clicks but kind of bad because now there are accidental NO CLICKING! Hope that you can help me, I'm used to the Macbook configuration and would love to just have a big ass left click! (Lenovo Y510P Windows 8.1)
Gibs
16
#13
Yeah I had that problem at first too, but instead of disabling the click altogether I changed it to be the same as the primary click. If you look on the first page of this thread my solution is posted.
I too came from a MacBook and Windows 8 feels really funky.
    Intel Core i7
    8GB
simondva
Sorry if I'm just being blind, but I don't quite see the option for changing to be the primary click instead of the context menu.. In the picture you posted is says "Enable secondary corner click" but right next to that it says "clicking in the lower right corner opens the context menu" and there doesn't seem to be a way to change that... Again sorry for the trouble and thanks for your patience!
simondva
OK I got it working! For anyone who wants to do this but don't know how here are the instructions:
1. Download the latest Synaptics drivers from their webpage: Drivers | Synaptics
2. Uninstall your current driver.
3. Follow the instructions on this web page to correctly install the new drivers (answer voted 2) : installation - Synaptics - Windows 8.1, updating Synaptics failed - Super User
4. Open the Synaptics driver to set up your click pad, click "clicking" and then hit the gear icon for settings
5. Set the corner of your click pad to do whatever you want (in my case since I'm used to Macs I selected Primary click). While your are in there check out the three fingers click, it's a cool way to open chrome really really fast.
6.Hit close and then apply.
To the current or future Mac lovers turned windows users (for whatever reason) that want some things to stay the same.
Cheers.
JP56
37
#16
Same prob - solved for me (Sony Vaio)
I had the same problem with my Sony Vaio 13.
The problem was solved by going into the Synaptics settings > Tapping > untick 'Enable Tap Zones'
I unticked this button and - hey presto - all sorted. Now left click reliably and happily use two finger tap 100% reliably for right click action!
    Win 8.1 Upd 1 Pro
    Sony Vaio Pro 13
    Intel i7
    PCIe SSD
    FF
    Bitdefender
Gibs
16
#17
JP56 Yeah the Viao's have more intuitive setting control from what I understand.
Simondva glad you got it working.
    Intel Core i7
    8GB
