Solved How to combine two partitions on the same hard drive
daniellouwrens
    Windows 8.1 x64 with 8.1 Update
    Asus
    Intel(R) Core(TM) i5-3450 CPU @ 3.10GHz
    Asus
    8Gig
    Poor
    Asus
You would need to be specific about what you are asking. Can you post a screenshot of disk management and which partitions you want to combine?
Most 3rd party partition managers will do it, if the partitions are on the same HD and of the same type.
    7/8/ubuntu/Linux Deepin
Hi
here is a screen shot, I want to merge New Volume E and New Volume R
Thanks for your help
Daniel
    Asus
    Asus
    8Gig
    Poor
    Asus
You can't merge non-contiguous partitions, so from what I see, this is what you need to do.
Delete E:
Move all the other partitions to the left so the free space is to the right of R:
Expand R: to encompass the free space.
This is a good program to do this with: Free merge partitions into bigger one with merge partition manager software in Windows 2000/XP/2003/Vista/2008/Windows 7/8.
This is another that is Linux based: GParted -- A free application for graphically managing disk device partitions
Before I would do this I would create image backups of anything I was not willing to lose.
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
@whs,
I think only PW PRO will merge, not the free version as far as I know.Although the extend function can take unallocated space from anywhere it seems.
@Daniel
Aomei is the best freebie for that. It will merge adjacent partitions. It will also merge with a non adjacent unallocated space. It will do the data moving automatically. If you have a lot of stuff on the intervening partitions ( H and P ) then it is a long job.
Free Partition Manager - AOMEI Partition Assistant Standard
    Windows 8.1 Pro MC
    Asus G75VW / Z97 Pro
    Intel Core i7-3610QM / I7-4790K
    Z97 Pro
    16 GB Hyundai HTM315156CFR8C-PB PC3-12800
    nVIDIA GeForce GTX 670M (GF114M)
    VIA 6.0.10.1600
    Samsung 850 Pro 256, Samsung 850 Pro 1TB
    30 down 3 up
    Explorer 11
    NIS and Malwarebytes
@whs,
@Daniel
Hi
thanks to everyone who helped, the AOMEI PA worked well, and I will certainly be using it again in the future.
Thanks
Daniel
    Asus
    Asus
    8Gig
    Poor
    Asus
Made an account just to thank this post, merged two partitions which were non-adjacent and it saved me a load of time!
