How to always remain connected to wireless network?
bkchng
Hi!
I'd like to ask how I could remain connected to the wireless network, even if an Ethernet cable is plugged into my PC? Currently, my work involves constantly plugging into and out of the wired network, which always disconnects my SSH sessions that were originally created over the WiFi connection when the WiFi goes down.
Thanks for your help!
znod
What do you do when you plug in and out? I searched on "use ethernet wifi same time," and I found some links that might be pertinent to you. Give that search or a similar one a try. Maybe you'll find something of use.
    ASUS P8P67 Deluxe Rev B3
    16 GB Corsair Vengeance
    EVGA 570 SC
    Gateway
    Dual Boot:
    Cooler Master 932 HAF
    Zalman CNPS9900MAX-B CPU Fan
bkchng
I'm actually a network engineer so I need to physically plug my computer into switches periodically (for testing/configuration purposes).
I'm able to have both my wired and wireless networks active at the same time; it's just that when I plug in my Ethernet connection, my wifi connection automatically disconnects and I have to manually activate it again (which is a major annoyance for me).
I did a quick search using the words you suggested, but couldn't really find anything that "forces" the wifi connection to remain active.
But in any case, thanks for your reply!
znod
You are very welcome. And, yes, when I searched, I couldn't find anything that sounded exactly like a solution for you. Good luck.
    EVGA 570 SC
    Gateway
    Dual Boot:
wpcoe
This probably doesn't help solve your problem, but I can report that I can connect/disconnect the LAN cable that connects my Win8 desktop and Win8 notebook, and neither computer will drop its WiFi connection. FWIW, they all (including my WiFi router) are on 192.168.1.xxx addressing.
    Windows 8.1.1 Pro
    Home built
    i3-3225
    H77M-D3H (micro-ATX)
    12GB
    none (Intel HD4000 IGP)
    mobo integrated
    Dell U2312HM & Samsung 171N
    1080x1920 (portrait) & 1280x1024
    Intel 520, 120GB SSD
    Kingston SNV425S2 64GB SSD
    WD WD10EARS 1GB HDD
    Cooler Master eXtreme Power Plus 460W
    Silverstone TJ-08E
    Intel stock HSF
    Logitech K260
    Logitech M210
    10Mbps/1Mbps DOCSIS
chev65
Closed
Hi!
There is a setting for this in the Group Policy Editor. If you set it to disabled it will enable you to use both connections at once.
It also explains that the Ethernet connection will take over if both connections are enabled if the setting is enabled or is default setting.
I posted a screen shot to make it easy to find the setting. :)
    Windows 8.1 Pro WMC
    Home built
    Q9650 @ 4.05 GHz
    Gforce 780i SLI FTW
    8GB Gskill DDR2 1200Mhz
    GTX-480
    Asus D2 Xonar
    HannsG
    1680x1050
    Gskill 120GB SSD
    Thermal Take 1000watts
    Thermal Take Xtreme
    9 fans air cooled
    G15 logitech
    G9 logitech
    50mbps
