How fix a smaller screen resolution?
Turbo20VT
Hello,
I have a Windows 8.1 Pro, and Intel HD Graphics 4200 and Nvidia GT630M 2GB.
But How I can get a smaller resolution than 1366 x 768. (So Like 1200 etc, etc..)
How can I make it smaller?
Thanks..
    Windows 8.1 Enterprise - 64 Bits (Build 9600)
    Acer V3-571G
MilesAhead
Eclectician
Right click on the Desktop. Click Screen Resolution.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Raedon 340 MB dedicated Ram
    Built in
    1366 x 768
    640 GB (spinner) Sata II
    Built in
    Touch pad
Turbo20VT
I know how, but it's only possible till 1366. I want to make it more smaller than it can be..
    Acer V3-571G
CountMike
Got newest drivers ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
MilesAhead
Eclectician
Go to manufacturer's support page and find out the hardware limitations. Screen res depends on stuff like supported sync rates both vertical and horizontal.
    Windows 8.0 x64
    AMD EI 1200
    4 gb DDR3
    Built in
    1366 x 768
    Built in
    Touch pad
NiFu
Right click on the Desktop. Click "Screen Resolution". Then blue link "Advanced settings". Then button "List All Modes". There you can downscale up to 640x480.
But keep in mind: You need at least vertical resolution of 768px to run apps.
