How do I turn off Indexing in PRO 64bit
bawldiggle
Australia (East Coast)
How do I turn off Indexing in Win8 PRO 64bit ?
In Win7 it is easy...
But in Win8 there is no "setting" item :(
I would appreciate any help :)
PC is Dell Inspiron laptop
- loaded with all DELL extras
Go to Control Panel>Administrative Tools>Services>Down to Windows Search>Properties>either Disable(not so good) or Manual(much better)
:note:You should never totally disable a service as it can cause problem sometimes, it's always better to set to manual, and then the service will not be used unless you specifically try to use it.
