How do I set sort settings for individual folders?
desaque
1
Hi guys,
I would like to sort the files in a particular folder by, say, date modified, but NOT have this setting applied to other folders in my computer. For example, I would want the files in the other folders to be sorted by name. However, I can't seem to be able to do this in Windows 8 - changing the sort settings for a particular folder applies it to every other folder.
Is there a way to customize the sort settings for individual folders without having it applied across the board? I recall being able to do it in Windows Vista/7, but can't seem to find the option in Windows 8.
Any help would be greatly appreciated. Thanks! :)
23,575
Hello Desaque, and welcome to Eight Forums.
The tutorial below can help show you how to set your folder views per folder. However, it sounds like you are in a library instead of the actual folder location. In a library, all included folders share the same folder view. Only in the folder's actual location will you be able to have separate folder views. For example, "Music" library versus "C:\Users\(user-name)\My Music" folder.
http://www.eightforums.com/tutorials/9743-sort-group-arrange-items-windows-8-file-explorer.html
Hope this helps, :)
    3 x 27" Asus VE278Q
    250GB Samsung 960 EVO M.2,
    256GB OCZ Vector,
    Logitech MX Master
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
