Solved How do I keep Internet Explorer "Frequent Blocks"?
Ken429
Internet Explorer has this nice feature that shows the sites you have visited most frequently under "Frequency" when it starts up - I'm using "Use new tab" as the default start screen. Unfortunately, whenever you tell IE to Delete Browsing History it clears the Frequency blocks. I suspect this information is stored in a cookie(?) but don't have a clue which one. I use CCleaner most of the time to clean up the system so if I knew what cookie to put in it's "don't delete list" all would be well. I'm sure I'm not the only person with this issue and it has probably been solved by someone so....help would be appreciated.
    W.8.1 Pro Update 1
    Custom
    3770K
    ASRock Z77 OC Formula
    GSkill 2400-10
    None
    Samsung S27B350
    Mushkin Chronos DX-7 240GB, WD Raptor 250Gb, 3 -WD Raptors 500GB
    Seasonic X750
    Corsair 800D
    Swiftech Apogee HD 3X120 Rad
    Microsoft Sidewinder X4
    Microsoft Exporer 2.0
    IE11
    Malwarebytes
HippsieGypsie
It's Gururrrrrr8!
Hi there. Are you speaking of Modern IE "Frequent menu" via pressing F4 such as this?
If so, that is a part of your History and not recorded in a cookie. You'd have to set CCleaner not to delete History. Depending on how you have "History saving age" set in desktop IE, you can go into desktop IE to delete History individually by right clicking for the context menu to do so. I'd imagine we'd have to keep "Today" to keep Frequent.
BTW, I believe they would be called tiles in Frequent menu.
    8.1 Pro X64
    Acer T690
    Intel Pentium D Dual Core
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Dual case fans + CPU fan
    Acer Windows PS/2
    Wireless Microsoft Arc
    54mbp/s
    IE11
    Defender
Ken429
Thank you. I guess I'm obsessed with the @#$% cookies. I turned off delete history in IE and CCleaner and the Frequent Blocks remain. I don't know how long IE will keep the history but I can deal with that as you have shown. Thanks again.
    W.8.1 Pro Update 1
    Custom
    3770K
    GSkill 2400-10
    None
    Samsung S27B350
    Seasonic X750
    Corsair 800D
    IE11
    Malwarebytes
HippsieGypsie
It's Gururrrrrr8!
You're quite welcome. :)
How are you coming up with that page?
I never noticed this (below), although they keep adding to the Modern apps all the time. Now I'm wondering if history and cookies are kept for Modern IE and desktop IE separately. Also, settings in both might be different. I'll experiment some time. Try turning on "Keep data for favorites when deleting history". I wonder if "favorites" and 'Frequent" are the same thing?
Open Modern IE> Right click empty space to bring up the Tabs/Address bar > Tap/click on Tools wrench > Tap/click on Options in the popup context menu.
In the Options menu Tap/click "Select" under the History.
Turn on "Keep data for favorites when deleting history".
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
HippsieGypsie
It's Gururrrrrr8!
BTW, I'm not a big fan of cookies either. A necessary evil so to speak.
Having a Lumia Windows phone 8.1, AT&T and other carriers got caught placing a super cookie on the phone to track surfing history. I know AT&T bowed out of it after much complaining. Don't know about other carriers though.
    8.1 Pro X64
    Acer T690
    Acer/Intel E946GZ
    2GB (max upgrade)
    Acer AL1917W A LCD
    1440 X 900
    Thumb drives
    Standard 250 watt
    Acer Windows PS/2
    54mbp/s
    IE11
    Defender
