Solved How do I image one system to load onto another system?
BCoSK
I will be setting up many kiosks. Each machine will have it's own key for Windows 8.1.
I want to be able to make a copy of a completed machine and be able to load all third party software and settings onto other machines. What is the best way to do this and will it be an exact copy, i.e. all software will be installed on the next machine?
Thanks!
Brett.
    Win 8.1 Enterprise
popeye
Macrium Reflect has a boot CD creator that will allow you to restore the image to each machine. Just don't activate the first machine until you make the image to use on the others. Of course you need to use Macrium to make the image.
Do the machines have a CD/DVD drive or do you have a portable drive? Otherwise will have to do it with flash drive.
Oh, also the free version is for personal home use only.
EDIT: This also assumes all the machines are exactly alike when it comes to hardware.
    Windows 8.1 Pro 64-bit
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    8GB DDR3 PC3-12800 (800 MHz)
    HD4000 + GeForce GT 730M
    Realtek High Definition Audio
    1600x900 pixels
    Samsung SSD 850 EVO 250 GB
    ADATA SSD SP900 128GB
    90 watt brick
    Bluetooth
    Comodo
alphanumeric
slightly off center
Gold Member
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
popeye
    Acer V3 771G-6443
    i5-3230m
    Acer VA70_HC (U3E1)
    1600x900 pixels
    90 watt brick
    Bluetooth
    Comodo
alphanumeric
slightly off center
Gold Member
I haven't used it either but have seen it recommended many times.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
Maltesespace
Yep. If using in an enterprise situation you would need a paid cloning program like Macrium pro or Acronis. (I've used both and recommend either.)
If I were you I would do this: Before activating Windows on the "completed" computer:
Open a Command Prompt (Administrator) by right clicking on the start button and click the referenced. Do the commands:
net stop WMPNetworkSvc
cd sysprep
sysprep /audit /reboot
The system will now reboot. When it boots to the desktop, you will see "System Preparation Tool" dialogue. Make sure you select the options "Enter System Out of Box Experience" "Shutdown" and tick the "Generalise" box. Then click OK. The computer will shut down.
Now, boot from the Macrium/acronis boot disk/flash drive, and have external media handy to copy the image to, depending on the software you are using the steps are different but the general gyst of it is you want to "Back up my disks" "Back up all partitions"
Save the image to your external media, shutdown the kiosk, then apply the image to the rest of them. Turn them all on and run through OOBE and activate and all will be well :) You can also save the image for later use in case one of them has an issue, you can just re-apply the image.
    Windows 10 Pro x64
    Self build (Desktop) / Dell (Laptop)
    Intel Core i5 4690k (Desktop) / Intel Core i7 5500u (Laptop)
    Gigabyte Z97 (Desktop) / Dell (Laptop)
    8GB DDR3 (Desktop) / 16GB DDR3L (laptop)
    Nvidia GeForce GTX 970 (Desktop) / AMD R7 M270 (Laptop)
    Onboard
    HP Pavilion 27bw
    1920x1080 (Desktop) / 3840x2160 (Laptop)
    Samsung SSD 850 EVO 120GB
    WD Black 500GB
    WD Blue 1TB
    (Desktop)
    Samsung SSD 850 EVO 250GB (Laptop)
    Corsair 750w
    Ultra atx
    Stock heatsink
    Razer Black Widow
    Roccat Kone XTD
    250Mbps Down / 20Mbps Up
    Chrome
    ESET
