Solved How do I get to "Select Preferences" for OneDrive in W8.1
Ken429
I see the App for OneDrive on the W8.1.1 Start Window but I don't see any "Select Preferences" in a drop down menu that is referred to in a CloudDock article "7 OneDrive Tricks You Didn't Know About". Can I/Do I need to install the Desktop App in addition to the W8.1.1 App shown on the Start Screen? The OneDrive Desktop Help page says all I get is the ability to work share for Office if I install the Desktop App in W8.1! Is the Select Preferences Obsolete with W8.1.1? Slightly confused.
    W.8.1 Pro Update 1
    Custom
    3770K
    ASRock Z77 OC Formula
    GSkill 2400-10
    None
    Samsung S27B350
    Mushkin Chronos DX-7 240GB, WD Raptor 250Gb, 3 -WD Raptors 500GB
    Seasonic X750
    Corsair 800D
    Swiftech Apogee HD 3X120 Rad
    Microsoft Sidewinder X4
    Microsoft Exporer 2.0
    IE11
    Malwarebytes
alphanumeric
slightly off center
Gold Member
There are settings for it in Charms Bar > Settings > Change PC Settings > One Drive. I'm not sure there the ones your looking for though.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Ken429
Yes, I found those settings. They are all on or off. This is the Article I found Googling stuff on OneDrive. I suspect this is referring to the OneDrive App for W7 since I can't find anything that lets me do what Trick 1 is showing?!
https://clouddock.co/7-onedrive-tricks/
    W.8.1 Pro Update 1
    Custom
    3770K
    GSkill 2400-10
    None
    Samsung S27B350
    Seasonic X750
    Corsair 800D
    IE11
    Malwarebytes
    1TB Samsung 970 EVO Plus M.2,
    250GB Samsung 960 EVO M.2,
    Linksys EA9500 router,
    Arris SB8200 cable modem,
    Lumia 1520 phone
